Hey guys,
I’m looking into getting a tube mic preamp. Most likely the ART Pro MPA II. How would I go about connecting this to my Firestudio Project interface? I’ve watched a few videos and read some articles on the subject but would like to hear from someone here that has used it with this interface. Thanks in advance
Dell XPS 8930 - Win10 64-Bit i7 8700K 32GB RAM 512 SSD 2TB HD S1 2 Pro, S1 3 Pro & S1 4 Pro
HP Omen - Win 10 64-Bit i7 7700HQ 12GB RAM 1TB HD S1 4 Pro Firestudio Project x 2, StudioLive 16.4.2, Audiobox 44VSL Yamaha HS8 & HS10 Roli Seaboard Block & Lightpad, Nektar Impact LX49+, Fender, Gibson, Marshall, Mesa Boogie, Avatar, ADA, SWR https://www.zeroempire.net https://constantcollision.com https://www.youtube.com/zeroempire |
Balanced out on the preamp to any channel 3-8 on the FSP. Use a 1/4" trs to trs. inputs 3-8 on the FSP will bypass the gain stage on the FSP when you use a 1/4" connection.
Matthew,
Thank you for the reply. Can I also use the "returns" 1 & 2 on the back of the unit? The manual states that "Their gain structure is identical to the ¼” inputs for channels 3-8 and are typically used for signals not requiring preamplification" Just want to make sure I don't screw anything up.
you can take the returns of channels 1+2 . Works as expected.
MacBookPro 16" M1-Max 32 GB RAM 24C-grafics 1TB, using a 32" Samsung 4K display with Presonus Quantum 2626
MacOS 14 Sonoma (always latest version) External harddiscs Samsung T7 or Sandisc Extreme USB-C or WD-Black 3.5" - 7200 rpm on USB 3.0 (connected via OWC-TB-4-dock) Presonus Studio One Pro 6.X (latest version); Celemony Melodyne Studio 5; Softube Console1 MK II (always latest versions) PreSonus Faderport 8, PreSonus Atom, Atom SQ |
