I have a StudioLive 16.0.2, now only used for live performances but I want to start using it as my main audio interface in the studio.
At the same time, SL 16.0.2 is getting old, as long it works and I don't need a larger console I will use it but I want to prepare for the future. SL 16.0.2 has FW 400, should a FW 800 card work or is there any compability problems between 400 and 800? Anything other I should check before buying a FW card?
A musician and music producer from Sweden!
--------------------------------------------------------------------------------- Website (mainly in swedish): https://www.johanbakke.com YouTube: https://www.youtube.com/channel/UCe8-QI ... xuwMfQP3UQ |
I have a Firewire 800 Texas Instruments 1394 OHCI Compliant Host Controller from Sonnet that works also with my Studiolive 24.4.2 when using a 800 to 400 bi-lateral connector of good quality.
http://www.sonnettech.com/product/alleg ... 0pcie.html I`m also using the same with a UAD Sattelite and the 24.4.2 together with no sweat.
Two things to check:
- the firewire card must have a compatible chipset - you have to use a bilingual FW400-FW800 cable |
Bi-Lingual it was...
