25 postsPage 2 of 2
1, 2
Just wondering why you are still using Cubase 32 bit? Try installing the 64 bit version. It works much better.
Regards 8-)
PRock Studio
OS: Windows 10 Pro, CPU: Intel Core i7 4700K, RAM: 32GB/DDR4/2800MHz, Graphics: 4GB GeForce GTX 960, Mobo: MSI Z170A Gaming Pro Carbon, AI: PreSonus Studio 192 Mobile, DAW: Cubase Pro (latest version), Other Hardware: PreSonus TubePre, PreSonus HP4, Studio Monitors: Mackie MR5
https://soundcloud.com/prockstudio
by ramizgadzhialiev on Fri Jun 17, 2016 11:43 am
I have 32 bit and 64 bit Cubase. Most often I use 64 bit. But you do not think that should work well everywhere? I have already put 8.5.20, but still the old problems remain. Who is guilty? To be or not to be))
by jesusrivera2 on Fri Oct 20, 2017 2:27 pm
I have the same problem with the latest updates, i get 1-3 sec stops on audio and midi in cubase 9. i made a test with the same audio in Studio one and i didn't find any problems in studio one, i think Studio 192 only works in Studio one.
Crosshair Formula V, Windows 10 1809, 16 Gb Ram, FX 6300, Presonus Studio 192. Cubase 9.5, Ableton 10, Studio one Artist
by jesusrivera2 on Tue Oct 24, 2017 6:50 pm
jesusrivera2 wroteI have the same problem with the latest updates, i get 1-3 sec stops on audio and midi in cubase 9. i made a test with the same audio in Studio one and i didn't find any problems in studio one, i think Studio 192 only works in Studio one.
I find the problem it was a plugin that was doing the stops. i remove the plugin and it work without an problems. so if you find your audio stops for 1-3 sec make sure check your plugins effects.
by jameshickey1 on Sat Sep 22, 2018 6:14 am
i7 3770 3.4 Ghz 24 GB Ram Win 10 Pro latest update
Cubase Pro 9.5 64 Bits
Studio 192 having erratically behavior on USB 3 port. Notice after latest firmware update
I know I'm not the only one with the problem.
Picture uploaded with the Cubase with The Average Audio Processing load indicator going crazy with annoy sound.
Help very much welcome.
James
Studio 192 problems USB.pdf
(332.54 KiB) Downloaded 64 times
25 postsPage 2 of 2
1, 2
cron
