This has happened from time to time.
If i turn on the SUB37 when im in a song, S14 just shuts down without warning.
When i turn on the Faderport 8 when im in a song, S14 freezes and no responding.
Anyone else here who experience such things?
Intel Core i7-7800X 3.5GHz / Asus Prime X299-A / GeForce GTX 960 / 32GB Corsair Vengeance DDR4 3000MHz
Fractal Design R5 Black Pearl / Fortron Hydro G 750W / Be Quiet! Dark Rock Pro 3 / Samsung M.2 NVMe 960 EVO 250GB
Samsung SSD 850 EVO 500GB x 4 / 4TB HDD Storage / Windows 10 x64 / RME UFX / RME ADI-8 DS MKIII / Presonus Studio One 4 Pro / Presonus Faderport 8 / Adam Audio A77X /
// Synthesizers.com / Moog Sub 37 / Octatrack / Analog 4 / Korg MS20m / Beyerdynamics DT990 Pro / Logan SMII / Doepfer MAQ 16/3
by Tacman7 on Sat Aug 11, 2018 10:41 pm
USB devices have to be hooked up before you run DAW software.
That's why I like using legacy midi ports, you can plug them in whenever you want to.
Maybe that's changed but that's the way it been.
Studio OnePro5 64bit Melodyne Studio
Kitchen Computer
Win10 Ryzen 5 3600 - Radeon RX 590 - 16GB DDR4 3000MHz - 512GB SSD interface:Komplete Audio 6
by kaosikosmos on Sat Aug 11, 2018 10:46 pm
Theyre already hooked up. I just turn em on.
by Bbd on Sun Aug 12, 2018 8:23 am
Your specs show you using Studio One 3.X. What exact version is it?
I would remove and re-install your external instruments and Fader Port. Make sure you have their latest drivers and firmware.
When you test, try to disable any programs running in the background that could be interfering with Studio One.
If these suggestions don't help, please open a Support ticket.
OS: Win 10 x64 Home, Studio One Pro 5.x, Notion 6, Series III 24, Studio 192, Haswell CPU: i7 4790k @ 4.4GHz, RAM: 16GB, Faderport 8/16, Central Station +, PreSonus Sceptre S6, Eris 3.5, Temblor 10, ATOM
by Tacman7 on Sun Aug 12, 2018 9:11 am
kaosikosmos wroteTheyre already hooked up. I just turn em on.
That's the same as plugging it in.
Kitchen Computer
by kaosikosmos on Sun Aug 12, 2018 9:30 am
I am using S14, i have updated the specs now.
I always update drivers to the latest versions. :thumbup:
I had this thing also in S13
There is something funky going on with usb devices causes system instability.
Thats why i always try to remember to turn them on before opening Studio One.
I am just curuios if this is "normal" usb device behaviour or if its my computer thats got issues.
by Bbd on Sun Aug 12, 2018 10:46 am
Normal behavior is subjective in that I don't have issues on my side with USB connected devices.
Did you try removing them and re-installing? If you did already, then I would open a support ticket.
Thanks.
by Jemusic on Sun Aug 12, 2018 2:28 pm
In V4 I can turn on Faderport 8 after Studio One is booted and nothing happens other than the Faderport will not be functional. I just have to go External devices and reconnect and then all is fine. It is best to ensure all your USB devices are ON before you boot Studio One.
Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro
by BobF on Sun Aug 12, 2018 3:57 pm
Jemusic wrote It is best to ensure all your USB devices are ON before you boot Studio One.
Yep. There isn't a DAW I've tried that deals with this stuff in an elegant way. In Win anyway. I can't speak for Mac stuff.
Freezes and crashes are almost always a driver problem regardless of the DAW. That's my experience anyway.
Studio One Pro - latest
Win10Pro x64 (latest) i7-6700 @3.8Ghz / 32G / 43" 4K
UMC1820 / Event PS8 / FaderPort Classic / KKS61MK2
Maschine MK3 / Waves Gold / Nomad IS3 / IKM Max / K12CE
by Jemusic on Sun Aug 12, 2018 4:45 pm
Actually a USB device that is normally ON when you boot Studio One will pass the boot up procedure on the start page. Any that are supposed to be ON and are not, will show up pretty obviously with a big yellow exclamation mark during the boot up procedure. That should be a clue. One should watch the boot up procedure. It will often reveal something like this that has been accidentally turned off.
by waldermelo on Fri Jan 31, 2020 8:35 pm
I was having the same issue. Just purchased Faderport 16. Open studio one 4 and it keep freezing.
I used a different USB cable and everything works now great. It seems that the UUB is the problem
Users browsing this forum: BobF and 27 guests
