Dear Presonus Team,
By accident, I was storing a new scene, then check it out.
I When I was checking, I recall the Zero Out, (and I wanted to recall my new scene)
but I pressed the store button while Zero Out was selected.
The SL32 got frozen. I have to turn OFF & ON. everything was fine.
This is just a suggestion;
If the store button get pressed while Zero Out is selected, the mixer should do nothing or a message "it cannot be change" or something similar.
Just an inside for the new firmware.
Thank you
Bogar
Mac Pro (Mid 2010)
MacOS High Sierra 10.13.4
32 GB RAM
Studiolive 32 series III firmware 2.01.16038
Studio One Pro
by PreSonus Seth on Mon Jun 18, 2018 8:32 am
It shouldn't do anything, hence why the Store button does not blink like on the other slots.
I can't reproduce the freeze. Probably related to the other freezing issues anyway.
by bogarguzman on Fri Jun 22, 2018 5:41 pm
Thank you very much Seth.
I update the firmware to 1.9, and now it does nothing, not even light ON as you say.
For a strange reason the issue was on the firmware 1.8, then, after many other issues, I thought I could have a corrupted firmware, due to many installations (updates from 1.0, to 1.6, another 1.6, to a 1.7 to another 1.7 and the 1.8), using the SD Card.
So, I did a Factory Reset to the factory firmware 1.0, the UC for updating directly to 1.8 by Ethernet, UC downloading firmware 1.8, and everything works like a charm.
Just in case, I did another Factory Reset to firmware 1.0 and updated with UC, dragging the firmware 1.9.
Everything is super stable.
Thanks again.
Bogar
Mac Pro (Mid 2010)
32 GB RAM
Studio One Pro
