Is there any way to render a midi track that follow the chord track? like you can with midi Note FX. I've tried to render instrument track, but doesn't seem to render the notes by the chord track. I would like to be able to render the midi as generated so I can turn off follows chords then make adjustments to the midi track manually.
Windows 10 Enterprise 21H1 ASUS TUF B450-PRO GAMING ASUS VP28U 4K Monitor AMD Ryzen 9 5900X 12 Core 64GB DDR4 3200MHZ MSI GeForce RTX 3060 GAMING X 12G Zoom UAC-8 Audio Interface Studio One 6 Pro (Latest Version) Notion 6 (Latest Version) Sonar Platinum x64 Lifetime [ YouTube ] [ Omnisphere Libraries ] |
I'm not quite sure if I follow the use of the term "render" in this question. To me the idea of rendering an instrument track is to render it as an audio track as played through the virtual instrument. Maybe synonymous with mix down, or freezing. in some contexts.
But it appears that you have used the term "render" with the intent of working with rendered MIDI note data in this case. So are you are looking for something to generate MIDI note data (where no note data currently exists) based on the chords in the chord track? As far as I know the chord track only alters existing MIDI note data that you have either played, or entered, into the track. I think that video in the link above is very helpful. |
Thanks for the reply, I did see that video when it first came out, but doesn't answer my question. Yes I mean bounce the midi as midi but with what the chord track has supplied, rather like when you use the arp in not FX, if you render, it renders the midi with the arp as midi note data. Maybe it`s not possible at this time?
EDIT: Actually just had a thought and just tried something. It is possible by saving the project as a midi file, then re-importing the midi. Would be just quicker though if we could render it, just like Note FX.
markrobotham wroteI would like to be able to render the midi as generated so I can turn off follows chords then make adjustments to the midi track manually.Musical Functions > Freeze Pitch |
niles wrotemarkrobotham wroteI would like to be able to render the midi as generated so I can turn off follows chords then make adjustments to the midi track manually.Musical Functions > Freeze Pitch Excellent, thank you!
Users browsing this forum: No registered users and 80 guests
