Well I have a project almost totally finished. the skipped notes are actually stopping me from finishing. This is still not fixed, not sure why someone said it is.
jih64 wroteThe issue occurs for me not starting at zero, plays fine until it loops, then the skipping begins. This is my concern. Try loop starting at zero vs looping starting at say bar 3.
jpettit wrotejih64 wroteThe issue occurs for me not starting at zero, plays fine until it loops, then the skipping begins. Same thing, skipping starts as soon as it starts to loop. As I mentioned in my thread a couple of weeks ago, I couldn't get it to happen in any projects that were created in previous versions https://forums.presonus.com/viewtopic.php?p=151867#p151867 |
Can you give us some more info. I am assuming you are using a virtual instrument. If so which one? Which preset? Can you upload a shot of the midi event open in the piano roll editor. Is the midi event polyphonic or monophonic?
BFD3, it's in the link in my post above.
I just had a mess around with 3.5.2 again (went back to using 3.5.1 when this issue became apparent) I usually leave my buffers set at 128 while tracking etc, never had an issue. When the drop out protection feature thingy came in I set it to medium (512) but still had my audio interface at 128, never had a problem. Just now I had a thought and fired up 3.5.2 and changed the dropout protection setting to Maximum (2048) with audio interface still at 128, there were no issues at all in the time I experimented. Still something must have changed to make it different than it was previously in 3.5.1 |
jih64 wrotejpettit wrotejih64 wroteThe issue occurs for me not starting at zero, plays fine until it loops, then the skipping begins. Like I said the developers said it had to do with starting from zero, but you lead me to believe it has more to it. So it only occurred the song was started in 3.5.2 and then only in a loop?
That's correct, I couldn't get it to happen in any project that was started in a version prior to 3.5.2. And it definitely occurs whether you start from zero or any other position in my tests anyway. You can copy paste a section on to the end until the cows come home and it will play fine all the way through, as soon as you loop a section the note skipping begins as soon as the first loop starts..
jpettit wroteThe issue that was addressed only occurred if you started at zero. Thanks, jpettit. I tried 3.5.2 again today and I did not hear any skipping notes when not starting at zero, so it's good to know about this temporary workaround. Every time I started at zero, though, the missing notes issue would be there, so I'm glad a fix is in the pipeline. I did not hear any skipping notes when looping sections (as long as I didn't start at zero). |
jpettit wrotejih64 wroteThe issue occurs for me not starting at zero, plays fine until it loops, then the skipping begins. My humblest apologies, I had a serious brain fade , the talk about the Start and zero I was applying to the loop itself, and not playback . . . and it just occured me that it was referring to the starting playback[/i] at zero and not the start of the loop. So to confirm, If I don't start [i]playback from zero everything seems fine, All good now, back to using 3.5.2 (Fingers Crossed) Apologies once again. |
Users browsing this forum: No registered users and 29 guests
