Here is a handbook on the topic Please read it first.
V1.0 downloaded 288 times. V1.1 downloaded 421 times. V1.2 downloaded 367 times. Revision History: 1. Initial Release 5/23/2017 1.1. Added LLM plugins behind the scenes logic and clean up 5/24/2017 1.2. Added LLM Punch-in Procedure and more logic on Instrument buffering 6/1/2017 1.3. Added additional options for Audio Punch-in 6/27/2017 Knowledge base FAQ When reporting issue always include
SPECS:Win 10 64-bit, 12 Core i7: 32Gb DDR4 ram, 40" 4K monitor, StudioLive 24, Quantum, Faderport16, Central Station Plus, Sceptre 6,Temblor T10, Eris 4.5, HP60, Studio One Pro 4.0, Reaper 5.9, Sonar Platinum |
No questions so far.
This is working AMAZING with RME drivers at the moment. AMAZING. This is the absolute most stable DAW experience I have witnessed to date, only rivaled by Reason 3.0 (I can only speak of what I know... I haven't really used Reason like that since 3.0) I'm in AWE so far. AWE. Hoping I'm not speaking too soon, but something tells me I'm not. This thing is stable as a rock.... no jumpy CPU meter... clean audio so far. I'm loving this. I feel like I have hardware at my fingertips.
Win 8.1 x64 // i7 3930K (@ 4.2GHz) // Samsung Pro 512GB // 500GB SSD (via Raid 0) // 32GB RAM // MSI X79a GD45 Plus mobo
DAW(s): Studio One v3 // Maschine Studio // Reason 7 Plugs: UAD 2 Quad, Klanghelm, Toneboosters, Soundtoys, others Instr.: a lot of stuff RME UCX // SM7b // Warm Audio Tonebeast12 & WA76 // Black Lion Audio Sparrow Red ADC // FMR RNLA // Korg Kaossilator Pro // Yamaha Motif XS Rack // Akai Advance 61 // Sennheiser HD 650 // Korg MicroKey 25 // Presonus Faderport // Contour Designs Shuttle Pro |
Thanks! Hope people don't overlook the link you provided pointing to the expanded 11 page documents. Nice work, Jeff!
Skip
so i take it you need a "Z" compatible interface? i think only my Avid Fast Track Solo showed a blue Z in the past within S1 device menu.
Consistently Inconsistent Ryzen 5 1600 : Asrock AB350M Pro4 : 32Gb 2400 RAM : Win10 64bit Macbook Pro 13 : 10th Gen Quad i5 : 512Gb SSD and 1Tb Glyph Atom SSD : 16Gb 3733 RAM : Catalina 10.15.5 iPad Air 3rd Gen : 64Gb : A12 Bionic : 10.5 inch Presonus 192 Mobile : Audient iD4 Ultrasone 900 Pro : Blue Lola : Blue Mix-Fi : AKG 240 Studio Samson Resolv 50a : Ik Multimedia iLoud Knot Hardly Productions ¯\_ { ͡• ͜ʖ ͡•} _/¯ |
Nope
Greens Z works with all interfaces. Have you tried it?
nope not yet... just opened a project to make sure all worked and started up is all. but i remember that blue Z from your pic. the webcast was somewhat quick and confusing to me about the "Z" thing
![]() Consistently Inconsistent Ryzen 5 1600 : Asrock AB350M Pro4 : 32Gb 2400 RAM : Win10 64bit Macbook Pro 13 : 10th Gen Quad i5 : 512Gb SSD and 1Tb Glyph Atom SSD : 16Gb 3733 RAM : Catalina 10.15.5 iPad Air 3rd Gen : 64Gb : A12 Bionic : 10.5 inch Presonus 192 Mobile : Audient iD4 Ultrasone 900 Pro : Blue Lola : Blue Mix-Fi : AKG 240 Studio Samson Resolv 50a : Ik Multimedia iLoud Knot Hardly Productions ¯\_ { ͡• ͜ʖ ͡•} _/¯ |
i read through it... but i am not good on written instructions
![]() ![]() but i think i figured it out some. i can lower my latency setup on my iD4 and raise the DOP and it goes into Green Z mode and auto compensates within the device menu. for example it raises block to 1024 samples in S1 while my iD4 is reading and running at 128 samples. or at least that is what i see p.s. but thnx for the pdf... it will help a lot of folks ![]() Consistently Inconsistent Ryzen 5 1600 : Asrock AB350M Pro4 : 32Gb 2400 RAM : Win10 64bit Macbook Pro 13 : 10th Gen Quad i5 : 512Gb SSD and 1Tb Glyph Atom SSD : 16Gb 3733 RAM : Catalina 10.15.5 iPad Air 3rd Gen : 64Gb : A12 Bionic : 10.5 inch Presonus 192 Mobile : Audient iD4 Ultrasone 900 Pro : Blue Lola : Blue Mix-Fi : AKG 240 Studio Samson Resolv 50a : Ik Multimedia iLoud Knot Hardly Productions ¯\_ { ͡• ͜ʖ ͡•} _/¯ |
Prior to 3.5, the CPU at a 32 sample rate would jump around like a dude at a 1990's acid tent party even on an empty track, adding a synthesizer instrument would inflict an arianism inducing effect if played, now it doesn't even move a muscle, (the CPU meter that is). On bigger tracks, I often ran my CPU into it's knee's to the point where it was virtually unplayable, the side effect of which would freeze the mouse pointer and where I'd also have to wait for my CPU recover from the cardiac arrest to carry on and pick up the instruction to stop the playback of the track. From my initial testing, 3.5 has solved much of this. A big demanding track will still require the original higher sample buffer to hear how it sounded before but it feels as if the song and the application are independent from each other and not effectively penilised for any changes you make settings wise. Overall it's more fluid, if your track sound bad at 32 samples it sounds like soup but changing settings thickens the audio up to how it's supposed to sound if raised higher. So overall it's very good....latency down to 0.4ms at 32 samples on my Focusrite Pro 14 firewire based interface
Last edited by scottmoncrieff on Tue May 23, 2017 7:08 pm, edited 2 times in total.
THE INTRANCER- Digital 2D & 3D GUI / Music Artist |- Full Orchestral -Trance - Ambient - Film Scores 27 on S-Cloud 7000+genuine plays | 16 on S-Click | Studio One 3 Concept Re-Designs - Sample One XT | Reason X | S-O-3 Pro | Reaktor 6.0 | Reason 7 | C4D | CS6 |Win 7 64 Bit-Intel I7 920@3.57GHz,Focusrite Pro 14, ATH M50's, Casio XW P1&G1 Producer 20+ years - FOH - UK Stadium / Festivals) >>Studio One 3D GUI's<<
jBranam wrotei read through it... but i am not good on written instructions Yep hardware as low as you are comfortable with. Drop Out protection as high as you need to avoid dropouts. Turn Green Z on. That is it.
Great job and thanks Jeff for the manual! It helps a lot.
I have a Steinberg UR44 which is not supported for hardware low latency but it sure is responding well to the native option. I did not think I would ever get this low of a round trip while recording. Very great release!
Please add your specs to your SIGNATURE. Search the STUDIO ONE 5 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. OS: Win 10 x64 Home, Studio One Pro 5.x, Notion 6, Series III 24, Studio 192, Haswell CPU: i7 4790k @ 4.4GHz, RAM: 16GB, Faderport 8/16, Central Station +, PreSonus Sceptre S6, Eris 3.5, Temblor 10, ATOM, ATOM SQ |
cool... may have to dust a guitar off on the morrow and check out the audio feed... but if i am reading it right... according to the low latency box... it is around 12ms with the settings i have it on now which would be tolerable with everything else going on
![]() but i definitely want to go to a thunderbolt connection but can't afford it right now ![]() Consistently Inconsistent Ryzen 5 1600 : Asrock AB350M Pro4 : 32Gb 2400 RAM : Win10 64bit Macbook Pro 13 : 10th Gen Quad i5 : 512Gb SSD and 1Tb Glyph Atom SSD : 16Gb 3733 RAM : Catalina 10.15.5 iPad Air 3rd Gen : 64Gb : A12 Bionic : 10.5 inch Presonus 192 Mobile : Audient iD4 Ultrasone 900 Pro : Blue Lola : Blue Mix-Fi : AKG 240 Studio Samson Resolv 50a : Ik Multimedia iLoud Knot Hardly Productions ¯\_ { ͡• ͜ʖ ͡•} _/¯ |
ponceoverton wroteI'm running version 3.5 as of today Tuesday May 23rd 2017. All I can say is I like a lot of the new features but this version is extremely buggy I can't export audio or playback without dropouts no matter what setting I use in the audio device options. As much as I want to say it's great, it's anything but that for me at this point. Needs an update right away. You are doing something wrong for sure. I just finished a live recording of 16 tracks, I mixed the stuff, did bounce. Rock solid. No need for any update right away. |
ponceoverton wroteI'm running version 3.5 as of today Tuesday May 23rd 2017. All I can say is I like a lot of the new features but this version is extremely buggy I can't export audio or playback without dropouts no matter what setting I use in the audio device options. As much as I want to say it's great, it's anything but that for me at this point. Needs an update right away. Tell us your parameters. Start with playback with dropout scenario. What are your all your buffer sizes? Song complexity? Etc.
Original document V1.0 downloaded 288 times.
Replaces with V1.1 grammar/punctuation edits on May 24 2017.
jpettit wroteOriginal document V1.0 downloaded 288 times. I must be pretty special because I dont see a document or a link or a download or anything but flat text in all your posts in this thread. Could someone point the local idiot in the right direction? |
jpettit wrotePlease ask all your Audio Dropout Protection and Low-Latency Monitoring questions here. Jbonez, Where is the handbook you mention in the op? Can't find it Thx!
https://soundcloud.com/brotherbrim/sets ... ernational
Win10... S1 pro latest version... 64 bits... Rme latest drivers... All the ram and i7 monster... |
There now.
Hi Jeff...
Once again a big thanks for all of your help and efforts. But... unable to open the pdf handbook in your link (tried multiple times)! Is it just me? Regards....
It downlods for me.
Is it now downloading or you?
Steve Carter wroteHi Jeff... He works for me... |
