29 postsPage 1 of 2
1, 2
Just tried Capture for the first time, successfully recorded some audio etc , transferred to Studio One a breeze, all good.
Now, looking at the help pages within Capture, I want to delete the session.
I can "edit" the list of sessions, then I get a red round button, which when I click on it turns into a red button with a bar across it. Click - done, nothing happens, session remains.
There must be a simple way to delete, I am following the user guide within the app exactly, it simply says, click on edit and delete.
I've tried swiping, clicking "done", double clicking the red bar etc. Nothing removes the session.
Simple? Not at all....!
Simon
MacMini M2 - 24GB RAM, Metric Halo ULN-2 (2). OSX Ventura, Studio One V6, Dorico 4 Pro, Mixbus 9 32C, Cubase 12 Pro.
http://www.scardanelli.com
http://www.Vi-ViD.net
by johndiaz1 on Fri Feb 10, 2017 5:50 pm
I'd like an answer to this as well. I am experiencing the same thing. Hoping they fix this bug in an update or someone knows a fix.
by Scardanelli on Thu Feb 23, 2017 4:57 pm
...and I still haven't found what I'm looking for...
by IndexJazz on Sat Mar 25, 2017 1:22 pm
Anyone find a solution yet? Thanks
Studio 192 / DP88
Studio One 3.3.4, UC 2.0.1.42326
iMac Retina 5k 27" i7 quad 4GHz 32g RAM
OS Sierra 10.12.4
by Scardanelli on Sat Mar 25, 2017 2:05 pm
Yes, it is the usual swipe from the right to left, but it seems to be a little haphazard in the exact place you swipe...be careful, but it will work from the list of songs, place finger to he right of the song you want to delete and swipe left, it may take a few goes to get it right! It's bad implementation of the iPad technique on the part of Capture I believe - if Im not the only one having trouble....!
by deltiongco on Thu Sep 28, 2017 7:11 pm
I just receive my Audiobox itwo today, Sept 29.
Here is how I was able to delete a session in Capture Duo:
On the main menu Tap on Edit
Press with you finger the Session you want to delete
Once you see the Minus sign, Press on the PLUS sign on top of the Sessions listing
The deleted session should disapear
It worked for me!
by finngruwierlarsen on Sat Jan 06, 2018 8:28 am
Currently this seems to be the only way that works for me:
- Completely close Capture (double-tap iPad button and remove Capture form the list of running apps)
- Start Capture
- Press 'Edit'
- Put a finger in one of the red circles and drag it to the right (a horizontal bar must appear in the circle)
- Press the checkmark icon above the red circles
You can only delete one session at a time, and the app needs to be restarted again if you want to delete another one.
I don't know if this cumbersome procedure is intentional or a bug.
by scotttroyer on Tue Mar 20, 2018 7:49 am
It's March 20, 2018 and this problem still hasn't been resolved. PreSonus, please look into this. Sessions cannot be deleted from within the app. Sometimes the app is wholly unresponsive.
My rig:
iPad Mini 2
iOS 11.2.6
Capture 1.0.2.38667 iOS (Built on Jul 20 2016) <--- there's the problem
My Workaround for Deleting Files:
  1. Download iMazing to your Mac
  2. Open iMazing and connect to your iPad
  3. Transfer to your Mac any audio you want to keep from the session
  4. Delete the entire session within iMazing
  5. Open Capture on you iPad
  6. Select the session you deleted. Capture will throw a warning that the session files cannot be found and ask you if you want to delete the session. Confirm the deletion.
by bartonpopenoe on Mon Jun 11, 2018 10:57 am
I've got a workaround that may help others, as I was having a multitude of issues with Capture for iPad that were driving me crazy until I discovered this "solution" by accident.
I found that most of Capture's functionality was a one-command-only operation, and in order to execute a second command I needed to re-start the application. Because that's a frustrating way to work, I decided to delete the application from my iPad but wanted to transfer all of my audio files first.
That's when I discovered that when the iPad was connected to a laptop with a lightning cable, the app works perfectly. When working this way, adding, deleting song and tracks works as expected. Not very mobile but at least it's a usable workaround that keeps Capture for iPad out of the trash bin.
Hopefully Presonus uses this info to determine the source of the issue and correct it.
by bartonpopenoe on Mon Jun 11, 2018 12:10 pm
I was pretty excited when the above solution was working. I did manage to get all of my songs exported to my laptop without restarting the Capture app, but the excitement was short-lived. I'm back to where I was before: One command, then re-start to get the app working again.
I've come to the conclusion that the Capture file data (plist or xml) must become corrupted after working with a relatively small number of files. My plan is to transfer my recordings out of Capture soon after creating them, and deleting the files from my iPad. Currently, I deleted and re-installed Capture from my iPad so that I could start with a fresh data file.
by richardmcbrayer on Fri Jun 15, 2018 12:14 pm
finngruwierlarsen wroteCurrently this seems to be the only way that works for me:
- Start Capture
- Press 'Edit'
This one worked for me, but I could only do one session at a time...
by Robertlottman on Sat Sep 22, 2018 10:43 am
Deleting Capture sessions is very easy, when the opening screen appears go down to where your recordings are, today, yesterday, etc under the ? mark to the right of the date recoreded swipe a short motion to the left and the word Delete will appear then press the red delete, poof its gone
by martinduell on Thu Feb 28, 2019 12:02 am
Yes i m also facing same problem..Code worked for me but i could do only single source at a time..Any solutions to it?
by martadavidson on Mon May 13, 2019 2:30 am
Did anyone find a solution for this issue?
Marta,
https://thegreatdevice.com
by girishbhatt on Wed Jun 12, 2019 4:23 am
The CameraDevice may be utilised to make a CameraCaptureSession, that is unique to this CameraDevice. A CameraDevice must get a frame configuration for every output raw framework through the CameraCaptureSession. 1 configuration in, just one raw framework out. The configuration defines camera attributes like aperture, autofocus, effects, and vulnerability. Because of hardware limitations, just a single configuration may be busy in the camera detector at any given moment; this can be known as the active setup .
A CameraCaptureSession explains all of the probable pipelines accessible to the CameraDevice. After a session is created, you can't remove or add pipelines. The CameraCaptureSession keeps a queue of CaptureRequests that turn into the active setup.
A CaptureRequest adds a configuration into the queue and selects one or more (or all) of those accessible pipelines to be given a frame from the CameraDevice. You're able to send many catch requests within the life span of a capture session. Each petition can alter the active configuration and place of output pipelines which will obtain the raw picture.
https://www.mygiftcardsitesx.com/
https://www.mysubwaycardx.com/
https://www.greatlakesloansz.com/
https://www.mcdvoicez.com/
https://www.freedomapkx.co/
https://tutuappdownload.me/
https://gbwa.me/
https://www.checkgiftcardbalancex.com/
https://www.walmartonex.info/
https://myonlinesurveyz.com/
https://mypremiercreditcard.loginsx.com/
by zainabkhan on Thu Aug 29, 2019 7:16 am
Delete files from a session Press Backspace on your keyboard. Alternatively, press the trash icon on the toolbar. The files are placed in the Session Trash Folder, where they can be deleted or retrieved. Empty the Session Trash folder by selecting File>Empty Session Trash.surveyforcustomer
by zainabkhan on Thu Aug 29, 2019 7:19 am
I use Capture one 6 Express on my laptop to preview images with clients on location. ... When I start capture one and go to the Library tab it automatically shows all sessions. I've searched and searched and can not find how to remove session favorites from the list.krogerexperiencee
by eugenesmith3 on Thu Oct 24, 2019 7:03 am
Is this still an issue?
https://www.knowitalllearning.com
by irmannazarra on Sat Nov 16, 2019 7:50 am
It is interesting
Thanks
by adamlevine4 on Sat Dec 07, 2019 12:46 am
Visit wendys restaurant and win exciting food coupons and cash prices by participating the survey. Register here for survey: wendy's.com
29 postsPage 1 of 2
1, 2
