Hello Studio One Users,
the maintenance update 3.3.3 is online. Here the announcement thread with release notes. viewtopic.php?f=213&t=22840 Happy discussion! Ari
snb1 wroteActivate all inserts still doesn't work in 3.3.3 Back to 3.3.1 for me. Yes this one slipped through. You can deactivate them, but cannot activate them back. You can use the list in the performance window as a workaround (the checkboxes) |
You may look at this differently, but the Global FX On/Off feature works exactly as designed. It toggles between "deactivate all" and "previous state" (which isn't "all on"). If you manually activate a plug-in or insert FX Chain while in "global off" state, this state gets cancelled and the new state replaces the "previous state".
arndkaiser wroteYou may look at this differently, but the Global FX On/Off feature works exactly as designed. It toggles between "deactivate all" and "previous state" (which isn't "all on"). If you manually activate a plug-in or insert FX Chain while in "global off" state, this state gets cancelled and the new state replaces the "previous state". Hey Arnd thanks for chiming in. We are talking regarding an issue reported where the Global FX button stops responding(with sessions that used mixdown function already) You can use it to turn of the inserts, however it stops functioning afterwards. This is is the issue thread: viewtopic.php?f=213&t=22516&p=123192#p123192 A workaround is to use the performance meter checkboxes, however you loose the logic of the Global button, you are talking about. Wish you all happy holidays Regards J |
montek wroteChange decimal values of TEMPO - use: SHIFT + mouse wheel ! Does not work on my system! Are you on Windows or Mac? Cordially Patrice |
AMD Ryzen 3950X, ASUS Creator x570 Mobo, 32GB HyperX Predator RAM (3600mhz), Radeon™ RX 5500 XT 4GB GDDR6 graphics card, RME Fireface 800, Windows 10 Pro, Studio One 5, Reaper 6, Cubase 10.5, Avid Artist Mix (EuCon please), Behringer X-Touch One, MIDI Fighter Twister, various other MIDI control surfaces and hardware instruments
g&s productions wrotejep ... BUT Row 7 in the Monitoring Table does not work like this anymore: no ZLM, Tapestyle off, Monitor off should show meters input / do not hear live input - but there are no meters input shown This really is a major bug that desperately needs attention, please, please , please Presonus, get this sorted as quickly as possible , many people use this workflow when recording and in most circumstances it is an absolute necessity. |
Users browsing this forum: No registered users and 76 guests
