After many hours of testing, I can't get the digital signal into Peak (or GarageBand).
I updated the control panel and mixer software to 1.1 and did the firmware update. I'm using s/pdif in to the firebox. It is locking on the signal and passing the signal to the headphone out just fine. It also passes the analog signal to Peak and Garage Band via main outputs (1&2). But I have not been able to get the digital signal (via firewire) into my MacBook Pro. Mac control panel (sound) sees the Firebox, and so does Peak, but after hours of testing, still no success. Soooo, I'm wondering if this is even possible. Appreciate any help.
Reason: Fixed title. |
The Firebox is compatible with Mac OS up to 10.7 so, theoretically, it should work.
I'm using s/pdif in to the firebox. What are you feeding the s/pdif input with? A preamp with s/pdif out?
Hey Stephen
Just a quick one from me Did you turn on the s/pdif on your Firepod mixer aswell ? Ch33rs Saga
Studio One v2.x 3.x 4.x-
Windows 10 Ultimate 64Bit AMD Ryzen (3.4Ghz) and 32gigs RAM Graphic: Radeon 5700XT To add your software and hardware specs to your signature to make it easier for us to help you, click HERE. |
From Jacob Duley, Presonus Tech Support . . .
You should be seeing a 7/8 input pair for the S/PDIF inputs. If those aren't showing up in Audio MIDI Setup then it sounds like the FireBox should have its firmware reprogrammed. Note this required sending the box back to Presunus. In case anyone else has this issue, that's what it takes to fix it. |
