OVERVIEW
UCNET (Discover on network) • Studio One can send Instrument track data to Notion 6 via new command "Send to Notion" via UCNet ( not Rewire). Notion will convert it to notation and open the new page in one click on Studio One. If Both Studio One and Notion have the same instrument it will share presets and you will hear it the same sound in Notion. This is useful to print the instrument data as notation. • Notion can send notation to Studio One with a new commands Send to Studio One. It use UCNet as well and not Rewire. The Instrument data will show up in a track and have the same preset if they both know about the plugins, and you will be able to play the instrument in Studio One. This is useful to transfer part or all of a score over to Studio One for more refined mixing. • You can also transfer audio to and from Studio One and Notion with the same command and different option. This is useful if you have a melody or chord progression and you want to write accompaniment parts in Notion. • You can also send 44.1k 16 bit files from Studio One browser directly to Notion 6. Rewire • Previously available Studio One as the Master and Notion as the Slave you can link the two together to add Notion instrument parts. • Previously available Studio One can record the Notion Instruments audio . • New Studio One can access Notion Rewire MIDI channels as input to its own Instruments and record the input. Drag and Drop 16 bit 44.1k audio form S1 browser to N6 Suggested Use cases: ( it depend on what you want to do and where you are more comfortable) UCNET
Limitations: As of this release UCNET only support new documents( song/score). You can however have multiple documents open in each app and use copy/past to move the data to an existing song/score. CRITICAL NOTE: Rewire and UCNet are not compatible. You can use one or the other not both. It take a full restart of Notion to stop Rewire. UCNet has been around since 3.0 in S1 but it new to N6. There are networking debug steps Here if you need to let your OS know about UCNET. ![]() ![]() Step by Step procedure: S1 to N6 UCNET procedure: 1) Start S1 and select track or song to export MIDI 2) Click Song/Send to Notion a prompt will come up to start Notion ![]() 3) Notion will start and prompt will change to option to send track ,song or audio mixdown ![]() 4) Select Notion on this computer, Send note data 5) Note data will be converted to notation in a track name that matches. ![]() HINT: If the Instrument is 'Grand Piano' and 'Grand Presence' in the Artist's instruments Keyboards folder or Presence XT Piano or Grand Piano a Grand Staff will be created in N6. Verify that you have Grand staff option set in the preferences. If the Instrument is known to both S1 and N6 ( a VST like Kontakt or SampleTank 3. etc the patch will be shared 6) Save the Song in N6.
SPECS:Win 10 64-bit, 12 Core i7: 32Gb DDR4 ram, 40" 4K monitor, StudioLive 24, Quantum, Faderport16, Central Station Plus, Sceptre 6,Temblor T10, Eris 4.5, HP60, Studio One Pro 4.0, Reaper 5.9, Sonar Platinum |
Thanks for this post Jeff. Very helpful!
Please add your specs to your SIGNATURE. Search the STUDIO ONE 5 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. OS: Win 10 x64 Home, Studio One Pro 5.x, Notion 6, Series III 24, Studio 192, Haswell CPU: i7 4790k @ 4.4GHz, RAM: 16GB, Faderport 8/16, Central Station +, PreSonus Sceptre S6, Eris 3.5, Temblor 10, ATOM, ATOM SQ |
I have installed Notion 6 (it works fine) and I've updated S1 to v.3.3.
When I click on "Send to Notion" it shows an error window saying Studio One couldn't detect Notion 6. There's a button to manually launch Notion 6 which opens the software, but it gives me the menu window, not creating a new sheet file with the Studio One midi track. Does anyone know how to solve this issue? Thanks
HP Envy Intel Core i7 CPU 3.07GHz, RAM 8GB
OS Windows 10 Pro 64bit Presonus Studio One Pro 3.5 Presonus Audiobox 1818VSL https://facebook.com/lizmartinmusic |
More importantly...
Rewire:
shihweichoo wroteWill N6 work with 3.3 artist the same way with pro version? Hello shihweichoo. Support for AU, VST2, and VST3 plug-ins and ReWire applications is available as an add-on from Presonus for the "Artist" version. However, I highly doubt that the "Interoperabilty" will be available without Studio One Professional. The menu items are different I'm sure. To say the least. So, if you want the features, upgrade to the Studio One Professional version to avoid hang-ups with compatibility. ,Newberry ![]() |
added video to OP
hello Jeff , thank's for the video of Markus , i waited for it , it's interesting and usefull for the fisrt approoch ! so i ve a question , in witch case do we have to use the REWIRE option insted of Discover the network ? in my case i use nerwork and my instruments are the one's of my Korg PA3X connected in USB and it work fine
See you Bernard from France |
Super cool of you to do this. Thanks so much.
I asked a question on a separate thread here:
I think I have a basic misunderstanding of how active this integration is between Notion and StudioOne. I was hoping for a situation where I could drag MIDI drum patterns (and other MIDI snippets) into StudioOne and have them appear in the Notion score. I was thinking/hoping that the two products are actively linked, to the extent that if content is added to the Notion score it is immediately available in the DAW and vice versa. It appears instead that the transfer is basically batch mode and really one-way for practical purposes. Is that a more accurate way to describe it? |
Thanks for posting the video, that is very helpful.
Two questions: 1. What if you change something in your score in Notion, is there a way to automatically update your session in Studio One? 2. What happens with dynamics / expression technique text? For example, if the score goes from pizzicato to arco, or from p to ff, is there a way to "convert" the midi messages into whatever VST you are using as plugins in Studio One? Both of these are crucial for orchestral film scores - creating a convincing midi mockup is pretty essential. |
peterroos wrote1. What if you change something in your score in Notion, is there a way to automatically update your session in Studio One? And vice versa? if you change something in your MIDI in StudioOne (e.g. change a pitch or duration), is there a way to automatically update your score in Notion? When I watched the videos, that was the impression I got. But I think it was the wrong impression. It seems to me the data transfer only happens on command. I am not criticizing. I just want to understand what is actually there. This two-way dynamic transfer of data is the Holy Grail. If it isn't supported yet, that surely ought to be the ultimate goal. |
craigparmerlee wroteI asked a question on a separate thread here: I saw you other post and I agree I would have implemented pure drag and drop between the two apps. I asked for that as a Feature when Presonus acquired Notion. S1 has always been killer at drag and drop. It seem to be foreign to the Notion team, however maybe we will see more of that in the future. It helps to start an FR in Answers as many of the changes in this update actually came from that database of requests. You can drag Audio from S1 Browser to N6 as long as it is 44.1k 16 bit.
peterroos wroteThanks for posting the video, that is very helpful. 1) No, not as of this release but it is in the plans 2) Have not tested, but from what I hear there are limitation to articulations being converted and transmitted via UCNet or Rewire.
jpettit wrotepeterroos wroteThanks for posting the video, that is very helpful. Thank you for your reply. These two things are really critical ... it is nice to be able to automatically send midi to a sequencing program, but the real magic is in a seamless integration between a notation program and a DAW program. This is a biggie for a lot of composers, film composers especially. As of this moment, the notation programs and DAW programs are still two different worlds ... if you can create something that will allow people to write a score and choose whatever VST they want, and control the basic functionalities (dynamics, technique, expression, maybe some simple automation) from one environment, you have found the goose with the golden eggs. |
jpettit wroteHINT: If the Instrument is Presence Piano or Grand Piano etc a Grand Staff will be created in N6. Hi, I've just been testing sending a piano part from Studio One 3.3, using Presence Piano or Grand Piano, to Notion 6. The piano data does indeed get sent over to Notion but appears on a single treble clef stave. I have made sure I'm playing a wide range of notes, from low to high, but it doesn't automatically appear on a grand staff. What am I missing? Thanks and all the best, Steve |
Did you turn the Grand staff import option on in the preferences?
I have only testing it on a few presets. Some work and some don't (more testing needed) I have a request in to describe what they look for to determine when to apply it.
