Hello,
We moved our equipment to a new building and for some reason when we connected our main speakers (2 Boss L1) to the main Output (one XLR to the Left and one to the Right) only the left side is working. What can the problem be? Do I need to enable the stereo function? Can anyone help? Thank you! [audio][/audio] |
you should try a reset, reflash the memory and reload the current ones see if that brings it back... did you swap cables and outputs from the mixer and verify all that... ? do the Control Room outputs function properly? is the mono out functioning
2- 24.4.2 consoles, 1- 1642 console, 1- 1602 console, 1- firestudio tube, 1-AudioBox USB, 1- PRM mic/ 1 DBX cal mic, 1- Behringer X32, 1 Behringer X32 Compact, 1-AVID SC48, 1-Midas Venue f32, 4-Midas Venue 240, Mackie and Yamaha analog mixers, 1 mac mini-on the 1642, 1- Open Labs XXL windows XP based mondo workstation, 1- Open Labs Sound SlatePro windows 7 hot-rod PC. Studio One Artist / Pro, ProTools, Ableton, Reaper, Meyer, QSC, Mackie, JBL speakers. Yamaha C7 Grand Piano with MIDI, lots of synths, samplers and modules, Spector NS2 bass, 2- taylor acoustics, Kay Upright Bass, G&L strat,
I am curious about this as I have had the same/similar problem happen in the last week as well. My right main output has dropped the audio output considerably. The meters are showing the same audio output but my right side is a LOT lower in volume than the left. No distortion in the audio output and it doesn't matter if I use the XLR or 1/4" output. All other sends/outputs are working as normal. I did a system reset and the problem persists. Nothing out of the ordinary happened to the mixer when the problem arose. I used it multiple times on the day that the problem occurred with no warning signs that I am aware of.
When troubleshooting proceed by trying to characterize the symptoms. Re-flashing the memory should ONLY be done if the problem is determined to be in the mixer. Do the easy, SAFE stuff first!
First do the easy things... swap the left and right XLR cables... Does the problem follow the speaker... that is, is the left side still dead or is it the right. If the left spaeaker is still dead, then the problem is with the cables or the speaker and not the mixer. Cables and the connectors are the most suspect. If the right speaker is now the dead one, then the output driver in the mixer may be blown. This could occur if you failed to follow the main rule when connecting the equipment and that is the power is supplied from a single source or receptacle. This means running a power cord alongside the snake to power the mixer. Using receptacles in different parts of a room or venue is asking for ground bounce to destroy input or output circuits. |
Sounds like a problem in the output stage. If reflashing didn't do the trick and you are certain there are no bad cables or issues with speakers/amps then it is probably time to contact PreSonus for service.
One note on the power - surge protectors won't do much good for ground and high/low voltage issues. For around $150-$200 you can get a decent true sine wave UPS (uninterruptible power supply) that will better protect your equipment investment. I use thus one: http://www.newegg.com/Product/Product.a ... 6842102134. It not only serves as a battery backup, it functions as a voltage regulator. Poorly (or not even) grounded electrical service, power blips, and low voltage (<110v) have been the problem behind almost every piece of gear I've ever had problems with.
StudioLive 16.4.2 and RM32AI, AudioBox 1818VSL, custom Windows PC (i5, 16GB DDR3, Crucial M4 SSDs in RAID1, FireWire 800, USB 3.0), Crown XTi 2000 (3), Crown XTi 4000 (2), Crown iTech 6000, Yorkville E215 tops, custom 2x18 subs (EV MTL2 clones), Antares AVP1, Digitech Vocalist VR, Shure SM7, Shure SM58s, SM57s, and a bunch of other stuff.
2002 Fender Geddy Lee Jazz bass 2001 Fender American Deluxe P/J bass 2001 Fender Jazz V (MIJ) active bass ???? Ovation acoustic bass |
The first thing to understand is this is a software controller, and ALWAYS the first step is to flash the mixer with the latest software and see if this solves the issue. (not a nice feeling when you send it in and there was really no problem with the mixer)
Next step is a Tech service ticket, so, give it a try and see if this helps! Best regards
Tower:
Asus Crosshair V formula Z motherboard AMD FX9590 4.0 GHZ 8 CORE CPU 16GB 2400MHZ RAM CAS8 512 GB SSD PRIMARY HDD 1.5 TB THOSHIBA 128MB 7200 RPM DRIVE 2.0 TB WD BLACK 256 MB 7200 RPM DRIVE AMD R9-290 4GB VIDEO CARD Windows 7 P sp1 2006 Imac Lenovo thinkpad Z565 upgraded with a Quad core processor, SSD and maxed out 8GB ram Win7 Sp1 Mac 2006 Ipad 3, Ipad 4, Ipad Mini Iphone 6s+ Audiobox USB 1818VSL i2 Studiolive 2442Ai SL 16.4.2 X 2 Studio 1/3pro Sony Sound Forge 10 Engineer / producer Owner Twilite Zone productions Owner Studio G |
Hi Guys,
unfortunately still there's no answer on this topic. Since last week it seems i'm facing a similar issue on my 24.4.2 Classic, precisely it's the hot-pin of the right Main out that is -20dB in relation to all other pins. The board is already at the local service, and I will report here when i have it back. Obviously it's a frequent issue on Studio live mixers, maybe this makes the difference between low- and higher-price mixers? Best regards from Germany Henrik |
Did anyone here open a support ticket? To do so click on the hyperlink in my signature.
Skip
Skip
For those that one side of the signal at the output XLR is low, that is bad news. The output driving chip is likely degraded. It is a bear to get to for repairing it. It is a surface mounted chip. REMEMBER to ALWAYS feed power to ALL interconnected equipment from the SAME power source. Connecting your mixer to a wall plug at the back of the room and your amps to one at the front of the room is sure to expose your mixer to ground bounce transients in the building wiring destroying inputs and/or outputs in your mixer.
I have the same problem. The right side drops out after about 3 hours. We can get through a practice, through a worship set, then about halfway through the message, the right side is gone. I say it is the board because I can take the 1/4" plug out of the left side and put it in to the right output and still get no sound.
Has Presonus ever responded with any valuable information on this? |
I am experiencing the same thing. I just lost the left outputs to control room and main out. Meters show strong signal but, no audio the left outputs. The rights are solid and work fine. Cables are good. Software is up to date.
Should I try reflashing. If so, where can I find instructions to do so? SL16.4.2AI |
henrikbraden wroteHi Guys, Do you know what was the issue? I have this same problem with my 16.4.2 Classic; the hot-pins of the LEFT Main outs are -20dB in relation to all other pins. -Juha from Finland |
Users browsing this forum: No registered users and 31 guests
