I hope this helps.
For Windows 7-64 It took a while, but it's working great. First: Hook up the keyboard via USB directly to your computer-- the standard MIDI ports are not needed. Important! Download and install the newest firmware for the keyboard. Shut down the keyboard. Download and install the latest driver for the Komplete Kontrol software. Do not skip this one! Restart the computer and power up the keyboard. Launch the Komplete Kontrol app. Click Edit; Audio and MIDI Settings. Click the MIDI tab. Enable "Komplete Kontrol -1" and "Komplete Kontrol DAW -1" on BOTH, the Inputs and Outputs Tabs. When you are finished, the window should look like this: Next launch S1-3. On the Start Page, click Configure External Devices. For the transport controls, proceed according to this video : https://www.youtube.com/watch?v=sDD1aik9mIw The transport controls work through Mackie Control. The To and From MIDI should be Komplete Kontrol DAW-1 When you are done, the screen should look like this: Next, click Add in the External Devices Window. Click New Keyboard at the top. Name it. Select ALL for MIDI channels. Select "Komplete Kontrol -1" for To and From. Check the Default Box if desired. When you're finished, the window should look like this: Shut everything down and restart. In S1-3, the Komplete Kontrol app should be listed in your Instruments Folder. Just drag and drop for tons of fun.
S1-3 Pro -- FireStudio Project -- FaderPort -- HP60 -- Sceptre S6 -- Temblor T10
Creation Station 400 v3 -- Intel Core i7-4770 @ 3.4 GHz -- 16GB DDR3 -- Velociraptor 600 D Drive Siig w/TI Chipset Windows 7 Home Premium SP1 - 64 Bit NI Komplete Kontrol 61 NI Komplete 10 Ultimate Antares AVOX EVO (64) ReVoice Pro 3 Lots of 3rd party VST's Korg M3 - 73 http://www.hookstownbrown.com |
Offhand guess:
Make sure Komplete Kontrol is in the proper location and then rescan in S1-3.
By chance did anybody here have issues with S1 version 3.2 hanging when trying to use Komplete Kontrol version 1.5 or higher? I had no issues until just recently. When attempting to open a song file that has a KK instrument track on it S1 hangs and I must kill it from task manager. If I open a fresh song file and try to add a KK instrument track to it the same thing happens. Worked great before.
That's a new one. Haven't heard of it before.
andystecklein wroteBy chance did anybody here have issues with S1 version 3.2 hanging when trying to use Komplete Kontrol version 1.5 or higher? I had no issues until just recently. When attempting to open a song file that has a KK instrument track on it S1 hangs and I must kill it from task manager. If I open a fresh song file and try to add a KK instrument track to it the same thing happens. Worked great before. Yes, I've had the same issue. |
Any way to browse presets on "native" instruments in S1 using the keyboard? For example, have a Presence XT or Impact loaded up and then browse presets of mentioned instruments?
Thanks.
Windows 10 64 bit Adobe Creative Suite Ableton Live 9 Presonus Studio One 3 Pro Presonus AudioBox 1818VSL Novation Launch Control XL Ableton Push 1 and 2 Native Instruments Komplete Kontrol S88 M-Audio Axiom Pro 25 KRK Rokit 6 G3 KRK VXT 6 Presonus Eris E5 Presonus MTM E44 [email protected] |
Looking for NKS support and Just found this, and set it up on S1-4, on my iMac. I can now use the S61 Kbd and control play, fwd, backward and stop. Thanks!
Edited: sigh... And now I have no midi from my Keyboard, but the controls were working great! |
Just moved over to a new computer and having weird issues. Keyboard is set up properly, shows NKS info in Browser, it is synced with Studio One, BUT the keyboard doesn't play anything? I am baffled, anyone else know what may be up? Other programs recognize it, so this is a studio one thing. I disconnected it, restarted everything, reconnected it in preferences.... So frustrated, hopefully someone can nail this one!
*** SOLVED -- if anyone ends up here, note that the instructions telling you to choose DAW -1 as your input / output were not correct for my computer for some reason. I used MK2 Port 1 for in and out and now I am getting signals from the actual keyboard. |
kristinkorpos wrote*** SOLVED -- if anyone ends up here, note that the instructions telling you to choose DAW -1 as your input / output were not correct for my computer for some reason. I used MK2 Port 1 for in and out and now I am getting signals from the actual keyboard. If you're installing your Komplete Keyboard for use as a Keyboard you choose the option with the -1 (port 1) If you're installing your Komplete Keyboard for use as a "DAW" controller (Transport Control) The Stop/Play/Record Buttons and fader POTS - Then you seled the DAW-1 option. Do not quote me because I have not tried it in Studio One - I know this from other DAW software - Which require the same steps to setup my KK.. Be Blessed... Edited Coinfusing Instruction - Aplogies for the old post visite- |
All working fine until I just updated Komplete Kontrol to 2.2.0 via Native Access and now neither Loop or Record buttons work in S1. Any help appreciated. (Just checked it in Cubase 10 and all works correctly.)
Those who can't dance always blame the band.
https://soundcloud.com/gerry-cooper-855281238 Windows 11 64 Bit, Installed Ram 16 GB, DDR4 3600 MHz, 11th Gen Intel(R) Core(TM) i5-11400F @ 2.60GHz |
Quietly wroteAll working fine until I just updated Komplete Kontrol to 2.2.0 via Native Access and now neither Loop or Record buttons work in S1. Any help appreciated. (Just checked it in Cubase 10 and all works correctly.) My problem with the last update of Komplete Kontrol and Kontakt is that they don't work at all anymore. Not as stand-alone nor as plugins. NI hasn't responded. It's been a week. Cheers, Mats N |
Users browsing this forum: No registered users and 65 guests
