way more and better info about AVB & Dante can be found here; http://www.presonus.com/downloads/products/pdf/RM_Applications_10-3-14_jn08_4WEB.pdf
Micro PA;
Apple; MacBook Pro 13", Mid 2010, 8Gb RAM, 500Gb SSD, OS X latest version Apple; iPad 3, 16Gb, iOS latest version Asus; S300C Notebook PC, 4Gb RAM, 250Gb HD, Windows 8.1 Studio One; v2, Artist StudioLive; 16.4.2 (sold) StudioLive; RM16Ai (returned) Behringer; X32 Producer (sold) Behringer; XR18 (ordered) Electro Voice; ZXA1 Heil Sound; PR22, Handi Mic Lag; 1984 RockLine Bass |
I wonder if there is a new picture that includes AVB cascading including a CS18?
Sound 4-U! reinforcement and mobile recording serving Tulsa and surrounding areas.
Dale Christenson 918.261.7263 StudioLive RM32ai StudioLive RML32ai CS18ai MOTU AVB switch ULT15 x6 ULT18 x2 SL AI328 speakers x4 StudioLive 16.4.2 classic Windows 8.1 SSD computer with UC Surface, Capture2, and StudioOne2 Producer |
Firewire is a local connection, so you can only record signals from the connected mixer (or play tracks back). In the combination RM16AI/ slave and RM32AI/ master the RM16AI adds 16 analog input channels to the network, which are numbered 33 to 48, and 16 digital channels, numbered 49 to 64. Input channels from RM32AI are not "mirrored" in RM16AI, just mains, mono out and auxes 1 to 8. There is nothing to record on the RM16AI, but I suppose it will be possible to to feed tracks into the network through channels 49 to 64 (the RM16AI as slave).
I wanted to know what happens
... when RM32AI is Master and firewire is connected to RM16AI: You don't get any signal from Capture into your network. ... when RM16AI is Master with firewire connected: Capture can record tracks 1-16 and playback tracks 17-32, which are in this configuration analog channels 1-16 and digital channels 17-32 in the network. RM32AI adds analog channels 33-64. It makes no sense to cascade RM mixers and to use them in the traditional way (FOH, stage). A single RM32AI serves everything you need. You can control recording through UC Surface even if your computer is "somewhere" (connected ia firewire to the RM). But you might use your RM16AI to expand your physical input channels up to 48. Another idea might be to get a CS18AI as controller for your RMs. |
After some more "investigations" there is some good news for you: Yes, everything you are asking is possible! I stand corrected. Please read the whole story in this thread: viewtopic.php?p=108947#p108947.
Still a bit unsure of some aspects of this. I'm using CS18AI and RM32 with AVB connection via MOTU AVB switch. I need to record onto MacBook Pro so I use the Firewire link from RM32 to MBP and record with Capture. This is for broadcast purposes so I have the CS18, RM32 and MBP in the Control Room and take analogue audio from a conventional stagebox in another room. I'd like to put the RM32 in the other room and simply run cat 6 back to the CS18 and the MBP.
When I last looked (several months ago now), I couldn't record audio via AVB to Capture (hence the Firewire approach). Saw something the other day that looked like I can do this now if I keep the AVB switch at the Control Room end and run the Cat 6 to the AVB port on the RM32 in the live room. The AVB switch also connects to the ethernet port of the MBP and the CS18. I don't want to do this wirelessly (even if it's do-able). All firmwares are up to date. Have I misread things and this is still to come? |
For CS and RM nothing has changed up to now. Recording is only possible through Firewire or via Dante, but Capture and CS18AI do not "speak" Dante...
There is some kind of workaround. You can "cascade" two RM mixers as master and slave. Your CS18AI is able to handle this setting. This brings Firewire back to FOH/CS and it works with any combination of RM/RML rack mixers. The RM's are connected via a single CAT5 cable to the AVB switch and it doesn't matter where the switch is located. Probably the best place is where most of the connections have to be made. AND: Firewire allows you to use Smaart on your MPB, so give your MBP some more work to do than stupid recording. Also an iPad may be helpful, if you want to have a look at the many details of two RM's working as a tandem. Your tiny CS controller can not represent all that... |
So the bottom line is that I'd need to spend many hundreds of GBP to buy an additional RM rack to utilise its Firewire for recording. From a tech perspective I see how this works but from a financial perspective it seems excessive when I don't need more than the 32 channels that I already have.
This is a problem I'd like to solve but not one that warrants that sort of investment. I'll carry on using an analogue stage box for the time being. Thanks for the steer Phil |
philmoakes wroteSo the bottom line is that I'd need to spend many hundreds of GBP to buy an additional RM rack to utilise its Firewire for recording. From a tech perspective I see how this works but from a financial perspective it seems excessive when I don't need more than the 32 channels that I already have. Believe me, there is no alternative in that price range. You cant buy a 64 channel mixer and recording 64 channels for +/- 3200€. (2x RM and 1 CS and AVB switch) |
Users browsing this forum: No registered users and 45 guests
