Per (http://support.presonus.com/entries/53849360-Faderport-setup-in-Logic-X-) I have my fader port mostly working with Logic X in Native mode. The only thing that doesn't work as expected(Per Manual) is the Automation control(Fader Mode). The Read, Write, and Touch lights are all lit up and selecting them simply toggles Automation on and off and in doing so turns all three lights off or on respectively. It does not change the mode. If you use a mouse to change the automation mode the three lights turn off and when you select any of them it reverts to Read and the lights turn on. The Off button does not change anything in the DAW, the light does turn on and off though when selecting the "Off" Button on the fader port.
If I set it up with HUI mode the automation correctly switches between modes(Latch with key combo doesn't work (which is probably expected and Off button still doesn't work) but the Window View follows the silk screen and not the User Manual (but I'm assuming this is expected). How can we get the Automation control fixed in Native mode so that the three mode buttons correctly select the mode, Write + Touch enables Latch mode, and Off correctly disables automation? Thanks. Logic X - 10.2 OSX - 10.11.1 Faderport FW - 1.3.8 |
Presonus StudioOne 6, Apple Logic Pro
__ macOS, macMini M1 1TB SSD / 16 GB RAM, MOTU M2, Behringer X-Touch & 2*X-Touch Extender, https://ansolas.de |
