I have put tracks (3 different drum takes) in 3 folders.
I want to use the FaderPort to jump between the Folders. The Channel Select "<" & ">" does not work on the folders, only on the tracks. Does anyone kown if it is possible, and if so - how to do it? |
I have managed to jump between the Folders now.
Programmed some buttons with the User Commands: Navigate Up / Navigate Down. My issue now is that when I jump form folder to folder, the solo on enabled folder does not follow the folder I chose, like it does when I jump from track to track. Also the Solo and Mute buttons only work on tracks, not folders. |
