I noticed since upgrading to V3 Professional yesterday that my fader is sticking or catching it will move a bit then sticks the action is definitely not smooth like it used to be. any ideas ?
Last year traded up my 3 firepod pod chain for a RM32AI. just added CS18AI And I am LOVING IT!. The Home Studio set up. Home built. Amd fx 8350 8 core 4400 Mhz liquid cooled. Asus M5A99X-EVO R2 MotherBoard, 16 GB Crucial Ballistix 1866mhz Ram, 120 GB Intel SSD , 1TB Seagate HDD, 4TB HGST NAS HDD, 500 GB Seagate HDD. Windows 7 Pro 64 bit, SiiG DP FireWire 800 3 port PCIe card, tripple monitors 27 inch Asus Monitor / 2 24 Asus inch monitors , Studio one 3 pro, RM32Ai firewire to pc, QSC RMX 2450, RMX 1450, RMX 850. Furman RP-8D power conditioner. Audix Microphones. PDP Platinum Series Drums
What fader?
Are you talking on the faderport?
Johnny Geib's Home Studio Trainer
Main Site https://www.hst-homestudiotrainer.com/ YouTube Channel https://www.youtube.com/channel/UCyrsF9 ... unUaVjDAog |
yes the fader on the faderport thats why I posted in the faderport section . it works fine as a motorized fader if i move a fader instudio one with my mouse it works as it should but if I grab the fader on the faderport it's like sticky.
I noticed tonight the the little right hand arrow or triangle on the midi icon flashes at a consistent rate . my faderport fader sticks when this light blinks
This usually indicates the track is in Read mode. Turn put it in touch mode and write some automation and see if it still sticks.
This is just the first thing to try.
themuzic wroteThis usually indicates the track is in Read mode. Turn put it in touch mode and write some automation and see if it still sticks. tried all modes no change still sticky
Ok, let me do some testing.
I deleted the faderport from studio one options menu . And deleted the faderport driver from the device manager. then shut down the win 7 pc . unpluged the faderport from the usb and power . power cycled the pc on then off . reconnected the faderport . started the pc back up opened studio one . faderport auto installed as it should and all work smoothly again
I'll have to write that one down. Thanx for the update!!
I just pulled my faderport back out to try with V3, luckily I didn't have any issues but glad you got yours working. I love the faderport lol.
SoundsAndGear.com - music production news, tips, reivews, and tutorials.
MaschineTutorials.com - exclusive tutorial and user community for NI Maschine BoomAndBap.com - drum library, plugin, and sample reviews MaschinePacks.com - expansion reviews and vst preset libraries for NI Maschine |
Sticky fader on my faderport is back
turns out the sticky fader for me anyway was related to the touch sensitive feature ie if i pushed down hard on the fader it worked smoothly. so I took it apart took the fader out bent the little tabs that hold the fader together . cleaned all the contacts .(be very carefull they are small and very delicate. I bent the contacts up slightly so as to make better contact . cleaned everything with alcohol. re assembled the fader rebent the little tabs that hold it all together . re installed in the faderport . reconnected and I have a smooth non sticking fader now .
Update .............repairs have failed !!!
now seeking a replacement fader from presonus. I believe it is a simple plug and play affair to replace
