How do you disable the noise gate?
Posted: Tue Jun 02, 2020 6:02 pm
by ben67
Hi There,
I have a couple of Eris E5s connected to a Tremblor T8. How do you disable the noise gate on these speakers, it's truly mind-numbing sorry!
I've searched for this but am obviously using the wrong search terms so sorry if this is easy.
Cheers
Re: How do you disable the noise gate?
Posted: Fri Mar 12, 2021 10:45 am
by andrewpeplinski
Hey, Ben67 - the Temblor has a standby feature, which kicks in if it doesn't see enough signal; I play music at a very low volume, and it tends to cut off a lot.
In all my searching, the only "solution" I found seriously risks frying the whole unit and completely voids the warranty (it involves soldering a couple of pins on the relay that controls that threshold).
Posted: Fri Mar 12, 2021 12:32 pm
by ben67
Thanks for the reply, much appreciated.
