I hooked up my new Tremblor T10 about a week ago. It was working OOB but today suddenly it does not make a sound anymore. My Steinberg UR-RT2 USB interface that I use for output successfully sends the signal through the Tremblor to the monitors via Tele > XLR to Sub, then XLR -> XLR to monitors, so the passthrough works when the sub is on.
Everything looks normal. The blue on light is on on the sub, the foot switch accurately makes it start blinking, but, either way no bass sound. I've tried all the switches and knobs on the back. I've tried disconnecting and reconnecting cables, I've tried to swap the power chord, I've tried to disonnect the foot switch. Nothing seem to work. The weird thing I have not changed anything in the setup that worked yesterday. How can it just stop working? Thanks for any input/help! |
hey, I also experienced the same thing.
I had it for almost 2 weeks now and I'm happy with the sound and details of the sub. But all of a sudden, now it seems like the LPF are not engaging anymore. It sounds like a mid cone and no bass sound coming from the speakers. Footswich is ok, the sound on my tops are ok. Just the low-end are not coming out of the T10 anymore. |
I have the same issue, but I didn't get to even enjoy any bass. The satellites work just fine (Samson Rubicon r6a), and my setup couldn't be more basic. I have an Eclere mixer connected to the sub, and the sound seems to be affected by the pedal, but there is nothing coming out from the subwoofer. I just got it two days ago, and I already see the nightmare of sending it back for an exchange or refund.
I own one.
It could be something simple or not. Support is your best option. Let us know how that goes! |
I experienced a similar problem. The Sub disappeared when I plugged in an additional set of Unbalanced inputs. Both were functional with pass thru, but no bass. I switched the polarity and the sub returned. (switching the polarity back again removes the sub). I have my sub bass back now but unclear why polarity would make a difference . Any insights?
Same, I just bought it and it just passes through. I can hear the monitors just fine but it's like the sub doesn't exists... I also watched the the setup video just in case but I connected everything to the right place.
Does anyone have anymore information about this issue? Did someone get it solved? |
