Temblor T10 and Temblor T8
Temblor T10 Sub question.
Just wanted to check if I set the LPF to 50Hz and turn ON the HPF switch, those lower frequencies on my main monitors are now turned off? Or is the HPF switch only set to 80Hz (only)
Thanks
by shanabit on Sun May 29, 2016 4:39 pm
My understanding is that the HPF is only on when you engage it with the footswitch which will disable the crossover in the sub and send full bandwidth to your top speakers. When the sub is engaged the crossover is turned back on and your LPF comes into play at that point
Its confusing to me as well :reading:
" High Pass Filter - Removes frequency content below 80 Hz from the full-range signal sent from the T10 outputs. The High Pass filter is bypassed when the Sub Bypass is enabled. "
S1 Pro 4.5.4, Sceptre S6's, MR816X, OSX High Sierra 10.13.6
2010 MacPro Dual 2.4 quad,14 GB Ram,
