Discuss Monitor Station V2 and Monitor Station (Legacy)
Central Station and Central Station Plus
MicroStation BT
Hello,
I have a Central Station. It has gradually developed an issue. The remote (when activated with the button on the back of the Central Station) will randomly switch itself, as if someone is changing the speaker selection. This issue has gradually increased in frequency to the point now where it does it so often I can't use it. If I de-activate the remote with the button on the back of the rack unit, the rack unit works as it should.
Has anyone had this issue? Could this be caused by a dirty cable connection?
Thank you very much much for any ideas you may have!
Caleb
by marcimboden on Thu May 09, 2024 3:25 pm
Mine is doing the same thing. Switching off the remote makes the issue go away.
