Static when adjusting volume on remote
Posted: Mon Jan 25, 2016 5:59 pm
by merc476
My remote has been making a back static noise when I adjust volume and when i use the talk back, it sounds staticy in the headphones. Sounds like some dust has gotten in it there. Anyone have this before. Any tips on fixing this issue? I tried the air spray but only helped a little. Thanks!
Re: Static when adjusting volume on remote
Posted: Mon Jan 25, 2016 6:05 pm
by matthewgorman
Once upon a time when there was radio shack, they sold a spray circuit cleaner that was good for dirty pots. May be something you can find at Amazon or New Egg.
Posted: Thu Jan 28, 2016 10:22 am
by merc476
Thanks. Ordered a can. Should be coming in today. In the meantime, does anyone know how to remove the volume and mic level knobs? Im trying not to break them. Twisting them counter clockwise doesn't seem to work and pulling them out isn't working either. Well, at least im trying not to turn and pull too hard and break it if that's not how it's supposed to come out. Thanks
Posted: Thu Jan 28, 2016 10:59 am
by Karyn
DON'T turn them.
They're either a push fit (if plastic) or will have a tiny locking screw (if metal) but they should just pull off.
They could be tight though, so maybe some gentle levering is required.
Posted: Thu Jan 28, 2016 11:35 am
by merc476
Thanks Karyn,
I was looking for the metal screw but there is none. I was trying to pull out and maybe I was being too gentle. I'll try again. Hoping someone from presonus can chime in to let me know exactly. Thanks!
Posted: Thu Jan 28, 2016 12:07 pm
by matthewgorman
It may be easier to spray the cleaner form the back of the unit. Take the back panel off. Or you could from the top with the knobs on. I think it will seep in.
Posted: Fri Jan 29, 2016 5:25 pm
by merc476
That worked perfect. Sprayed from the bottom. all is good now. THANKS!
