Suitable DB25->6 Stereo 6.35mm Jacks?
Posted: Wed Jun 15, 2016 10:48 am
I would like to add a HP60 directly above an RM16AI in a Gator 4U rack case.
I am looking for a short DB25 cable->6 x Stereo 6.35mm jacks so I don't have to either lose a large amount of cable tucked away in the rack somewhere (or carried separately) to use adaptors to go from the readily available 8 x Mono 6.35mm Jacks into the 6 Stereo ones I need.
It might be an even better idea to go from DB25->6 Stereo Jacks plus 4 x Mono so I can feed the signal into Inputs A & B or have I misunderstood how the HP60 is to be connected?
Is there an off-the-shelf solution?
Does PreSonus manufacture & sell such a lead?
Where can I obtain a suitable lead from bearing in mind I am based in the UK?
It have searched but as mentioned above I only see the DB25 that goes into 8 Mono Jacks and not the needed 6 Stereo Jacks but the shortest seems to be @2m long and I am guessing I need a cable @12" or so long.
I suppose I could butcher an off-the-shelf 2m lead by cutting & shutting but I would rather use a ready made cable.
Curious as to what solution you guys use and how you connect your mixer to the HP60?
Thanks & kind regards,
-=Glyn=-
-=Glyn=-
