Presonus HP 4 and scratchy potentiometer
Posted: Mon May 09, 2016 4:17 pm
by maxi200
Let me start by saying that there about two years ago I got rid of my controller monitors the SM Pro Audio Nano Patch Plus because after some time of use began to crackle potentiometer. I bought Presonus HP4 and after about 2 years started to happen exactly the same, in terms of the main pot of the volume of monitors, the other I use occasionally and so on headphones not noticed similar symptoms. You can fix it, and if that's the case that such a failure occurred on both devices, or it could be causing something special?
