Headphone Monitoring HP60, HP4 and HP2
Headphones including Eris HD10BT, HD9, HD7 and others found in the bundles can be discussed here
1 post
Let me start by saying that there about two years ago I got rid of my controller monitors the SM Pro Audio Nano Patch Plus because after some time of use began to crackle potentiometer. I bought Presonus HP4 and after about 2 years started to happen exactly the same, in terms of the main pot of the volume of monitors, the other I use occasionally and so on headphones not noticed similar symptoms. You can fix it, and if that's the case that such a failure occurred on both devices, or it could be causing something special?
1 post
