Discuss Eris E4.5, E5, E8, E44 and E66 here
There's a free small square thin foam that came free with my Eris 5. On the box, it shows that this should be put below the monitors for isolation. Does anyone actually put them below their monitors, if so, does it really help? Or is it too thin for isolation purposes?
by matthewgorman on Thu Dec 03, 2015 9:23 am
Can't hurt. I have foam under all my speakers. It helps define the low end when you can eliminate the acoustic coupling when a speaker is resting on a hard surface. You can get unruly resonance in some instances.
Matt
S1Pro V4
by kristabellesantos on Sat Dec 05, 2015 7:45 am
Yes. But this one is actually very thin. Should I still put it?
by skiltrip on Mon Jun 06, 2016 11:23 am
kristabellesantos wroteYes. But this one is actually very thin. Should I still put it?
I'd say if you have no other decoupling device (at least Auralex MoPads) then yes, put them on. If you use MoPads or something even better, I'd say the little stick on feet are redundant, and not to bother with them.
That said, you should definitely get at least MoPads if you're serious about getting the best out of your monitoring. It makes a really critical difference.
5,1 Mac Pro 2.4GHz 8-Core 2011 16GB RAM | 2018 MacBook Air 13" | Studio One 3.5 | Presonus 24c | Focusrite Scarlett 6i6 | Mackie 802-VLZ3
