Just opened a ticket but....
Has anyone else had any problems with the power supply in the E5 going south? Thanks, Jeff |
I had that happen to my E8s twice. The first time was only weeks after I got them and the retailer replaced the one without a problem. The second time was just recently when the speaker was just under a year old. PreSonus was very good about honoring the warranty and repaired it for free with a minimal of shipping lag time. Never have gotten an explanation as to what when wrong, or how I might prevent it in the future though.
Just happened to me!
I couldn't get them(tech sup.) on the phone today. Fingers crossed that they will fix this. My box is a little over a year, therefore out of warranty. I just hope i don't have to pay for a design mistake... Fuse blew during a mix session, changed the fuse and immediately blew again. Hopefully just a bad capacitor... I'm somewhat glad I'm not the only or first one.... |
antoniosilva wroteJust happened to me! It does seem like it is a design problem or a bad component in the design. All of these units are just right at the one year mark when these are failing. The MTBF (Mean Time Between Failures) of this component must be right at one year. I too hope that Presonus addresses this issue. |
Hi, my Eris e8 blowed fuse like you, it turned out it's a ceramic capacitor .1uF - 100V that burned out, The ceramic shrank so much from the heat that the two poles inside touched toguether, creating a shortage. I need to replace it. What's strange though, in my other Eris e8, it's a diffrent circuit board and have .1uF - 400V ceramic capacitor in it. The part cost almost nothing if you can solder it by yourself.
The capacitor 100V voltage rating is too low for either 120V or 240V. Sounds like it was a mistake. 400V is much closer to the mark. If the speakers are under warranty you might void it doing your own repairs. You need to be skilled soldering components around mains areas to ensure soldering is solid and strong. (Unplug before soldering!)
Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.1 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro |
