While doing a mix last night my Studiolive made a pop sound and started flashing. I quickly shut it down and rebooted. It flashed again 3-4 times and then another POP. This time a little smoke came out of the back Needless to say I am very concerned! Not sure how much a repair will cost?? Anyone else have this ever of know what it is??
While not sure it is most likley a capacitor in the power supply that has gone bad. That type of issue should be fairly visible if you open the mixer and have a look...
Agreed it's probably a bad cap. In the early to mid 2000s, there were tons of bad caps finding their way into everything with a power cable. They would dry up, internal impedance would increase, causing them to heat up, then they'd swell and burst.
I just went through some stuff I got from eBay and replaced a bunch of swollen caps. Open it up, find the scorch marks, and take some pics. If you can work a soldering iron, you may be able to fix it yourself -- although replacing through-hole components on PCBs with plated holes can be a bit of a challenge sometimes. You'll have to decide whether it's worth the trouble, or if you'd rather just have a qualified tech take care of it. |
Could be the input capacitor but better check the input surge limiter... probably labeled RT1 on the power supply board. If the coating is cracked, it is a goner. I got replacement from Mouser... I can get part number if you need it... cost was about $1.60 as I recall. This part will smoke when it goes... and should the cap go, this part will likely go.
WARNING: This is a switching type power supply and has lethal voltages. |
fredy2 wroteCould be the input capacitor but better check the input surge limiter... probably labeled RT1 on the power supply board. If the coating is cracked, it is a goner. I got replacement from Mouser... I can get part number if you need it... cost was about $1.60 as I recall. This part will smoke when it goes... and should the cap go, this part will likely go. Part number would be appreciated please. |
If you need spare parts, this link might be helpful:
http://www.fullcompass.com/brand/PRE_PreSonus/Replacement-Service-Parts.html. |
