Page 1 of 2
NO sound
Posted: Fri Jul 18, 2014 3:24 am
by antonracksha
Hi fiends!
I have bought used Presonus 16.0.2 some time ago. But I have one problem with it - I can't get any sound from this board. Firewire is working, signal is enters into the board, but no sound from main outs or headphones. May be anyone has same problem? Big thanks for any help!!!
Re: NO sound
Posted: Sat Sep 13, 2014 6:56 pm
by jeffcoley
Press the Firewire button and see if all the channels are set for Firewire (playback from computer). They will be lit in yellow. If so, press each yellow button on the channels and it turns it off, and you should have sound.
Re: NO sound
Posted: Sun Jul 17, 2016 5:22 pm
by laquitabailey
I'm have that same problem No sound, I can see the feed but no output, I've tried the FireWire button are there any other options? Thanks for any advice.
Re: NO sound
Posted: Sun Jul 24, 2016 5:43 am
by SPS
are you new to the board?
Please give the specs/info of your set-up. It's hard to support you without any information from your side.
First: See the firewire returnbuttons in the previous post
Second: did you route the channels to the mains?
Re: NO sound
Posted: Sat Feb 18, 2017 2:00 pm
by jabraham
I have a 16.0.2 and am suddenly having this problem. So odd, since I don't think I've changed anything since the last time I used it a few months ago. I will report back after fighting with it for a few more hours or days.
Re: NO sound
Posted: Tue Feb 21, 2017 12:13 am
by jabraham
jabraham wroteI have a 16.0.2 and am suddenly having this problem. So odd, since I don't think I've changed anything since the last time I used it a few months ago. I will report back after fighting with it for a few more hours or days.
I left my board powered off for a few days, then unplugged the Firewire cable and turned it on. I attached a dynamic mic to the talkback port and tried it out, and didn't think it was working, but when I attached the mic to a regular channel I started to get feedback, so it's working again. I also played around with the firewire buttons, but they seemed to have no effect.
I have no idea which, if any, of these caused it to start working again:
1) leaving it off for a few days
2) turning it on without the firewire cable plugged in
3) attaching a dynamic mic to the talkback port
4) attaching a dynamic mic to another channel
Re: NO sound
Posted: Tue Feb 21, 2017 2:42 am
by jabraham
I've been playing with this for a bit and I can force my board into no sound mode by changing the sample rate in Universal Control to 48 instead of 44.1. What seems to re-enable sound is to set it back to 44.1 in Universal Control, disconnect the firewire cable from the board, go to system page on the board (page 3) and set the sample rate to 44.1 (perhaps toggle to 48 and then back to 44.1), then turn it the board off for a few minutes, and turn it back on. If you have sound again, you can try plugging the firewire cable back into the computer, and the consistent 44.1 settings between the board and the computer will hopefully work.
I hope this technique keeps working for me, and I also hope it helps out someone else.
Re: NO sound
Posted: Mon Apr 10, 2017 11:46 am
by lance.dodd
Just a Note to anyone having this problem i fought this for 10 hours back and forth one night
i then in desperation switched off the ac power switch then PULLED OUT THE POWER CORD
let it sit around 5 minutes reconnected power turned on and magic happened all outputs working again so i left a signal running on the chan 1 input for 12 hours with the monitor on and in 12 hours it was still working pretty sure it was a 44.1 <> 48 sampling issue but nothing resolved it short of the full power down and pull out the power cable
Re: NO sound
Posted: Wed Apr 19, 2017 12:29 pm
by gkmachine
Yes, I'm having this problem too. Just started last week. It's happened twice now. The first time around I stumbled across this thread and tried the switching off, disconnecting and restarting etc.....and that did work. But now it's happened for the second time, the switching off and unplugging has not worked.
Is there a specific order of doing these things that people have found successful? I'm maybe doing it the wrong way.
Ideally though, Presonus will find out what this error is and resolve it.
Re: NO sound
Posted: Wed Apr 19, 2017 12:31 pm
by gkmachine
PS Further to my last post, I should say that the mixer stays where it is and is used every day and has been used every day for several years....if not to work from DAWs then even just to play back audio from iTunes, youtube, soundcloud etc etc.
Re: NO sound
Posted: Thu Apr 20, 2017 5:21 am
by wahlerstudios
"every day for several years"...
Then I would say think of getting a new mixer. Your old mixer has done a good job, so be happy and thankful. Nothing lasts forever, especially not digital hardware. Obviously your mixer needs a repair, which might cost more than the mixer is worth. Open a ticket in your PreSonus account and get advice from the specialists in Baton Rouge.
Re: NO sound
Posted: Thu Apr 20, 2017 5:23 am
by gkmachine
3 years is NOT a long time for an in-studio mixer!!
Re: NO sound
Posted: Thu Apr 20, 2017 5:28 am
by gkmachine
Let me be clear: as I specified, I did say that said "use" of the mixer is mostly as just an audio interface. It's never moved, re-wired etc. I only do music with it once a week if I'm lucky. But it IS permanently connected to my iMac which also acts as my office.
What I'm saying is that you have missed the point completely. The point was that 1) it is not used for live sound and so gets very little 'abuse;, and 2) conversely, it is NOT used so seldom that some change in utilisation goes un-noticed.
You get me now?
Re: NO sound
Posted: Thu Apr 20, 2017 7:57 am
by wahlerstudios
I agree, 3 years is too short, even though the mixer was used every day. But still: Open a ticket in your account and get advice from PreSonus. They know the problems the 16.0.2 mixers have and they should have a solution.
Believe me, I have read your posts carefully - and the posts before. The two first "writers" simply disappeared without any concrete information about their problem or a solution. The rest is about the 44.1/48 kHz toggling, which some classic mixers seem to need in order to get going. Actually this might indicate a computer problem because the computer is the "external clock". Unplugging cables and that kind of stuff might help in some situations, also refreshing or a new installing of firmware, but generally it looks like the problem is "built in", which means that something needs to be repaired or replaced inside the mixer.
Another theme is the life-cycle of the mixer (and the other SL mixers as well) and there are some "theories" around, but only PreSonus can answer this question - and they never will. Let's say so: I can not imagine any SL "classic" mixer surviving 10 years of daily use, even if it's only used for listening to music...
Re: NO sound
Posted: Fri Apr 21, 2017 10:47 am
by markus18
Hello!
First, sorry for my bad english... but i try...
I got some problem like yours. First i got sound in my headphones and monitors but when i reset scene (in audio box 118118 VSL) suddenly the sound disappear from my headphones. Still i can hear the music from the monitors. Actually i remember it had hapend me before but i can´t remember how the sound comes back.
I tryed to turn everything on and of but still - no sound
Anyone have some suggestions???
Re: NO sound
Posted: Fri Apr 21, 2017 11:36 am
by markus18
Well now i got sound...when i whent to audio setup and enabled Qmix for both main out and headphones (7+8 in audiobox 118118). But i still have the question: What is Qmix and why haven´t i got any need of Qmix before to hear from both headphones and monitors.
Thanks for answer´s
Re: NO sound
Posted: Fri Apr 21, 2017 4:07 pm
by wahlerstudios
https://forums.presonus.com/viewforum.php?f=191
Wouldn't this be a better forum for your questons? The forum here is about Classic StudioLive boards and this thread deals with the SL 16.0.2 especially.
Re: NO sound
Posted: Sat Apr 22, 2017 6:12 am
by markus18
Hoppsan! I was reading this forum and thought it was about studio live in studio one. I will go to another place. Thanks!
Re: NO sound
Posted: Sat Apr 22, 2017 6:38 am
by gkmachine
wahlerstudios......thanks....yes, I took up the matter with Presonus.....just in the process of answering some questions just now....cheers
Re: NO sound
Posted: Sun May 14, 2017 7:41 am
by easyline27
Same here, it was working for more than a year without any problem. Now I have sound from my laptop (main ex) but none of the entries are working...I tried mic with xlr, guitar with jack on every single entry. Install-re install. Opened a ticket.1 year and half is quite short
