I've had my 16.4.2 for several years and used it for live and recording in the studio with no issues till recently.
Just today I started getting quite low output from the main and VERY low and distorted output to AUX 1. I have it turned all the way through powered speakers, should be BLARING. Sounds like it's barely up. The mix through the headphones is fine as well as the send levels to Studio One. Knob on the back is all the way up. The other problem I have recently is in Capture, no level is sending to the stereo 17/18 mix for mixing down prerecorded tracks. Firmware 1.50a Build:190 Thoughts? |
reboot reload software update drivers and software and see if that clears it...
dump using Capture and use studio one instead... save yourself a few steps and have a better recording experience.
I sent an email to tech. Hoping to get an RA number. Nope. Was told to download drivers and do factory reset on mixer. I guess Presonus thinks the people that buy their boards are idiots. It's the 1st thing I DID. And it has nothing to do with anything about my computer.
*ARGH* Getting it fixed, then off it goes to ebay. Buying X32 in 3...2...1... |
Did you tell them you already did that? I'm sure that's the first step in troubleshooting. If you PM me your ticket number I can try to look into it for you...
All I meant was if you had told them you already did that they would not likely have sent that as a first step.
mrdarinwarren wroteI didn't tell them that. I just....want it fixed. Our support tech has a ticket open awaiting your response. Please look in your email as we do have a form for you to fill out and send back so we can get you your mixer repaired.
Forum Admin
Please add your specs to your SIGNATURE. Search the STUDIO ONE 5 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. |
Whether hooked to mac or not, same problem. Connected to Mac, opened U.C. and it says up to date, did factory reset again. Tried different mic, cables, powered speakers, playback from mac on 2 track in. All low output to mains and AUX's. Meters all say full signal. StudioOne gets full clean signal as does headphone jack on mixer.
Hoping to get this thing working soon. I've never had other problems with this console. |
Did you get the email with the support info?
Yes that is the latest... the way you can check this is to go to the release notes for the firmware that you are installing...the numbering system is a bit funky...and no there is not anything to worry about ...
If a firmware update on the mixer (even though it's a most current build the software can still become corrupt, so the first thing to do when experiencing a problem is to reflash) doesn't solve the problem, re-visit the Tech support staff about it... regards
Tower:
Asus Crosshair V formula Z motherboard AMD FX9590 4.0 GHZ 8 CORE CPU 16GB 2400MHZ RAM CAS8 512 GB SSD PRIMARY HDD 1.5 TB THOSHIBA 128MB 7200 RPM DRIVE 2.0 TB WD BLACK 256 MB 7200 RPM DRIVE AMD R9-290 4GB VIDEO CARD Windows 7 P sp1 2006 Imac Lenovo thinkpad Z565 upgraded with a Quad core processor, SSD and maxed out 8GB ram Win7 Sp1 Mac 2006 Ipad 3, Ipad 4, Ipad Mini Iphone 6s+ Audiobox USB 1818VSL i2 Studiolive 2442Ai SL 16.4.2 X 2 Studio 1/3pro Sony Sound Forge 10 Engineer / producer Owner Twilite Zone productions Owner Studio G |
No retro. Different guts.
Did you track the shipment? Can you PM me the ticket number? I can look into it for you...
mwright137 wroteDid you track the shipment? Can you PM me the ticket number? I can look into it for you... Yep, it arrived Monday. I just received an email like 10mins after I posted the question. I got things to record!! Anxious to get it back. In the interim, I may buy a small USB unit. Thanks, Darin |
