They appear from Google searches to be mythical. Anyone have a lead on where I can find a set?
by SwitchBack on Tue Aug 18, 2020 7:43 pm
The 16.4.2 sold with ears included so the ears never sold as a separate item I guess.
Probably the fastest way to a pair of ears now is find a metalworker and show him your mixer, the Mechanical Drawing and the Rack Ear Installation Instructions. Note that the screws used are countersunk metric type.
by jamiebastien on Tue Nov 03, 2020 7:57 am
Another option would be to make a set yourself. Its just a piece of angle iron whit holes drilled into it. You can get angle iron from Home depot. Just measure how high you need it and make sure the thickness is not any thicker than the brackets you are taking off. The mechanical drawings didn't really show that.
Here is an example of what you can get. Just cut it to length. You might have to drill a few hols but that would be about it.
Key words to search for is slotted offset angle iron
by SwitchBack on Tue Nov 03, 2020 8:13 am
The original rack ears are 1/16” steel, heavier than the brackets. The set comes with 8 slightly longer (6mm M3) screws to replace 4 side panel screws each side of the mixer.
by jamiebastien on Tue Nov 03, 2020 8:29 am
SwitchBack wroteThe original rack ears are 1/16” steel, heavier than the brackets, so the set comes with slightly longer (6mm M3) screws.
You now know how thick the metal has to be and the length and type of screws. The easiest option is to get a set made but if you are on a budget, you can get away with making them yourself.
by wahlerstudios on Tue Nov 03, 2020 11:58 am
They seem to be available, after all those years... ;-)
https://shop.presonus.com/1642-and-CS18 ... unting-Kit
Apple routers | iPads | Alesis iO Docks | Yamaha S112, S15e, S10e, SM10 | LD Systems Curv 500 | Galaxy Audio Hot Spots | Mac mini | Lenovo Laptop | Studio One Artist 5.1.2 & Pro 3.5.6
by wahlerstudios on Tue Nov 03, 2020 12:12 pm
You can find the "StudioLive 16.4.2 Rack Ear Installation Instructions" on the download page of your mixer.
https://www.presonus.com/produkte/de/St ... /downloads
