We have a StudioLive 24.4.2, and we have the sound output from a computer coming in to the Tape In input. Works fine as far as signal being present in main output. We need to get this signal into the Sub3 group that we are using for livestreaming. Is there a way to do that?
I guess the other option would be to run the computer output into one of the normal channel inputs (which we can include in the Sub3 mix), but when we try that, we see no signal there, even with the +48V button depressed. Any thoughts on how we can get this computer output signal into our livestream mix? Thanks! -bg |
No, Tape In can’t go to a sub. But it can go to an Aux output, so maybe you can take your live stream from there? As for plan B you’ll probably need a linked pair of mixer channels, e.g. channels 23/24. On the computer make sure you send computer sound to output channels 23/24 and on the mixer make sure the firewire buttons on those input channels are lit. That should do it really |
