Since I upgraded my OSX recently, Ableton no longer seems to get an audio signal from my StudioLive 16.0.2 USB. Everything else works fine otherwise. Ableton recognises the mixer and I have it selected as the input and output source. I can even send MIDI signals into my synths through the mixer and then feed the synths back into the mixer. I can see a signal in the mixer display, but when I activate record in Ableton no signal is noticed......I can't record anything! I've checked to see if I need to upgrade the driver but Universal Control says everything is up-to-date. I've re-started the computer, switched the mixer on and off, checked the USB connection (even though I didn't need to as I know it's working due to MIDI being sent and received) and checked system preferences, Audio settings, etc Any ideas? Screenshots of my computer's specs and Hardware attached. Thank you Gordon |
This article is kind of regarding Studio One, but the same can happen in any daw. Maybe this helps?
https://support.presonus.com/hc/en-us/a ... to-Mojave- |
I was reading through the Presonus support site and stumbled onto a question similar to my issues and your answer to someone else question solved my problem!!!!! Thank you so much, I literally have been trying to figure my issue out for days installing, uninstalling, changing cables and it was a simple check box to fix it...............
