Hi Guys,
I'm following the guidance set out in the link at bottom of this post as I organise and then transfer preset scenes from Device Memory in VSL to my 16.0.2 board. The Presonus link gives precise and helpful instructions for the 'drag & drop' of scenes from the 'On The Disk' browser into Device Memory as per below. To send your Presets back to the mixer, simply hit the "Send" button on the Device Memory. Once this is done, The Scene Memory on the mixer will populate the scenes in the exact order in which they were stored on the Device Memory section of VSL. However, when I hit the "Send" button on the Device Memory, although the scenes are successfully sent to 16.0.2, they arrive in what appears to be random order spaced across the whole of the 80 memory slots. This is NOT as described above i.e. "...populate the scenes in the exact order in which they were stored on the Device Memory" Such random placement, interspersed with *Empty Location* slots just makes it harder to quickly find the required saved preset scene when the 16.0.2 is used live. Am I missing something here or is this just how it works and guidance narrative is incorrect? I can of course re-order the scenes manually on the 16.0.2, re-saving them to the required memory slots in a sequential way using the Value encoder and this the tedious workaround I am current using. Any advice to understand what's going on to improve my workflow greatly appreciated ... https://support.presonus.com/hc/en-us/a ... p-Transfer |
So lots of views, but no feedback yet...
Am I the only person to have experienced this issue? But in addition to the scene order being scrambled, I also realised this weekend while at a live gig that the fx order had also been randomly sent to the board, meaning the mapping accessed via midi had also been disturbed which was a complete pain.... Still looking for clues guys... |
