Presonus Forum;
I'm in my second day trying to figure this out. I've searched the knowledge base with no results, posting here in hopes of answers. This is the scenario: • I have 8 live mics going into channels 1-8 on my 16.0.2. • In my DAW (Logic Pro), I see meter activity in each of 8 tracks receiving channels 1-8 from the 16.0.2. • I want only input from channels 1 & 2 on my 16.0.2 coming into my DAW. • I mute channels 3 through 8 on the 16.02. • I solo channels 1 & 2 on the 16.0.2. • Instead of only channels 1 & 2, all 8 channels in my DAW continue to show input meter activity. Why can't I isolate — mute or solo — channels in my 16.0.2 going into my DAW? Thanks. Cayce |
My guess is on the 16.0.2, I believe there is a setting that will allow you to not send audio to your DAW "with the mixer fat channel effects" and instead, audio is sent to you DAW directly after the pre-amp gains of each channel. You can change that setting so everything you do on your mixer WILL go to your DAW and I believe PreSonus refers to it a "printing effects to tape". Having this option gives you the chance to have a clean sound going to your DAW simultaneous to messing with the settings in the fat channel. In layman's terms, you can send audio to your DAW pre-fader & EQ or post fader & EQ.
I know the other Studio Live boards have this feature because I will record my live church service by having all audio recorded to my DAW (Logic) WITHOUT the fat channel settings, because during a service, I am doing wild things to compensate for the audio in the room and I don't want those room adjustments on the board to show up in my recorded audio when I take the DAW tracks into the studio to mix down. So simply press the (DIGITAL OUT-POST) button if you want anything you do on the mixer to show up in your DAW recording or de-select that option if you want a separate clean audio feed to go to your DAW. Otherwise I suppose you can mute the channels in Logic.... I hope this helps you. |
