studiolive 16.4.2classic
click from ableton coming into channel 4 feeding into aux channels. that channel slider is all the way down, but is slightly bleeding into the mix. used for a church setting so we have times of silence and I cant let that happen. hints/tricks/advice appreciated |
Even though you have the fader all the way down (which really should mute it in the mains) could you change the routing for that channel so that there is no way it can get in the mains? Select the channel, then just make sure that the Main and Subgroup lights are not lit and you should be good, it can still route into the Auxes.
That said something seams wierd to me, is that click going into a monitor speaker? It could be bleading into a microphone if it's coming through an actual monitor speaker. . . typically you'd use in ears with a click track. . . Steve
StudioLive RM32AI
Rackmount Windows 8.1 PC Quad core 8G ram ASUS RT-N66U Dual Band Router IPad2, IPad Air 2, Studio One 3 Pro, 1 DBX Driverack 260 2 QSC KW 153's, 2 Turbosound TMS-1's 2 OHM MR450D Subs with Kilomax 18inch drivers 4 EV ZLX-12P's, 2 Yamaha S115V's 4 Behringer EP2500 amps, 1 QSC Amp 10 58/57 mics, 1 AT2020, 2 AT2021, 1 beta52 kick mic 2 e609, 2 Radial J48 DI's |
Hmmm, sounds like you are bringing the click track in through FireWire. I'm wondering if it isn't going into more than just channel 4, it could be possible that it's coming into your cue mix, check to see if the FireWire button is on in your cue/headphone section of the mixer, if it is on try turning it off, also try turning the cue knob all the way down.
There is also a way to solo a channel or aux and have it go to the mains (I think) make sure channel and the drum aux are not being solo'd You need to do some testing when no one is there to trouble shoot this, try turning the drum aux all the way down, do you still hear it? Try turning that channel down in the aux, do you still hear it? Try turning all the knobs and faders down one at a time, when it goes away it will help tell you what the culprit is. Steve
StudioLive RM32AI
I know this is an old thread...but were you able to solve this? I have the exact same problem.
Series III, running click through channel into Auxes for IEM. Click comes from an audio interface, but it's run analog into the board. Channel isn't routed to house, fader is down, and it's muted. STILL get bleed into the house. Any ideas? -Scott |
This thread is not old. It's timeless...
![]() Make a simple test: 1) Disconnect USB 2) Load the Zero Out scene with all options active 3) Do a Master Reset of digital patching 4) Plug in your signal to channel 1, unroute channel 1 from "Main" Now you should hear the signal only in the auxes when you raise the aux faders of channel 1. The aux output faders need to be raised, too. Welcome to the Forum! |
