For some reason all the stereo channels on my 16.0.2 only work on the left input. I understand that if you have a single (mono) input that you are supposed to use only the left. But I am running from a stereo source so I plug into both the left and right 1/4" inputs. But I am only getting the left side signal out to the mains, headphones, etc.
Is there a setting I'm overlooking? I've even done a complete master reset of the unit in hopes that it will fix the problem but no luck! Thank you in advance for your help. |
Hi, did this issue ever get resolved as my 1602 has developed the same problem.
Only the left output works on the main outs Had to use the control outs on last nights gig. Hope it's not a big issue as I have already wasted 1500 quid on a 16 4 2 that decided to commit hari Kari The 1602 has been great up until now |
I had to figure this one out after having my 1602 for 3 days by looking at the circuit diagram to locate the problem Page 69 Link mode 'Pan' enabled
Steps to fix Stereo channels mono (L) only 1. Turn the stereo channels on by selecting the 9/10, 11/12, 13/14, 15/16 (White button). 2. Turn the 'Link' button on the left (White button) 3. Select the 9/10 stereo channels (Blue Select button) 4. Turn the 'Pan' clockwise from a single red line in the center to two yellow lines under "L" & "R" or the padded mix that you require. 5. Repeat steps 3 & 4 for all the stereo channels 6. DON'T turn the "Link" button off Hope this helps Sound Hound |
