Hi guys... need a little help here...
I own Presonus 24.4.2 and it was working on the soundcheck really great.. I stored the scene and mute all the channels (don't touched anything else, don't even turned it off... and 30 minutes before the show... CAN'T GET INPUT SIGNAL ON ANY CHANNEL... Universal Control is still corresponding and working fine, just won't get any input signal... not even in the talk back mic input... 30 minutes before the show 3000 people in audience I was lucky I had analog mixer in my truck... If someone had the same or similar problem and resolved it, please share your/the solution.. Cheers
Reason: Fixed CAPS LOCK |
Moved the thread into the appropriate forum
Studio One v2.x 3.x 4.x-
Windows 10 Ultimate 64Bit AMD Ryzen (3.4Ghz) and 32gigs RAM Graphic: Radeon 5700XT To add your software and hardware specs to your signature to make it easier for us to help you, click HERE. |
You didn't use the FireWire returns to do a virtual soundcheck, did you?
thats what i was going to bring up Mwright... FW enabled has fooled me a time or two...
Same issue tonight! In the studio listening to iPod on tape ins when all of a sudden audio sounds like it's being pushed through an eye dropper for about a second while I see mains meter ramp up, left all the way to red and right three LEDs lower, then no sound at all. GR meter runs full at the same time. Those meters are now stuck there with no input from anywhere! Checked with mic on every channel. Nothing. Any presonus tech out there see anything like this?
Just to clarify a few things:
- GR meter runs full regardless of the 'select' button engaged? - Only the main output meters are stuck, or other output(meter)s too? - FAT channel is still responding to changes from VSL? - FAT channel is still responding to changes from the mixer? I'm trying to establish if the whole mixer froze or if only inputs and outputs are blocked. And did you try the 'set ID=1, wait a few seconds, then set ID=0' trick? |
Same thing with a 16.4.2 i just bought it used from my local studio only 3days in my home studio and i get the GR Full
Every thing responds on the board but just no sound input... i tried the firewire ID change trick, it worked a few times then it just stoped working, I oppened up a ticket but i guesse that i wont be having service since im in canada... |
Hey, Guys! Recently the solution was found by user oscarmonsalvo. He wrote not so much about this. I tried to PM him some questions but he did not answer. I decided to check the information from his posts on forum. The problem caused by some voltage regulators feeding Analog-digital converters. Repair will cost less than a dollar. I wrote some guide of successful repairing my 16.0.2 console - it also can be useful for you. http://musiconnect.ru/publ/device/no-in ... -solution/
SwitchBack wroteJust to clarify a few things: I do get input volume but very low,, my Tape 2 track in don't work,, talk back mic don't work,, i coudn;t located firewire link anywhere |
Hello Presonus Friends. Hope someone out there can help, I have contacted Presonus and their support team stated that they no longer support 24.4.2. I have a StudioLive 24.4.2 hooked up and up to a week ago everything was fine, however upon trying to record today, channels 1-16 on my board have no input signal coming in at all, either from instruments nor XLR mic inputs. When I plug a mic into channel 17-24, there is signal coming in. It appears half my board is dead. I have tried re-installing the Universal driver and Factory reset via Universal control, but still no signals. Has anyone out there experienced this? Is there a fix somehow? Is it a hardware, firmware or some other issue? My DAW is REAPER. Any help would be much appreciated. I have attached the OHCI Information, interestinglt point 2 in the report states: Status: No Longer Present or disabled, but the Support States: Compatible, No known Issues
Thanks in advance for any tips to get it up and running again fully. Gez |
