Hi all,
Working with a 24.4.2 AI here. Trying to upgrade firmware to latest. When queried, the mixer responds that it is at version 1.0.16191. Then downloaded the correct version (1.6.16191) to a thumbdrive. The files on the drive are labeled with the correct version (1.6.16191). Went through the Firmware updating process on the mixer, and it responded that the update was successful. However, when queried again the mixer still responds that it is at 1.0.16191. I don’t know if the firmware is really not updating, or if the display is just wrong. The fact that the Firmware build number (last 5 digits) is identical in both cases makes me suspicious that the mixer is displaying the wrong #. Why would build numbers be identical for two different versions? Thanks in advance for any help you can provide! |
