Dear All
need help with this issue, i have presonus rml32ai and cs18ai connected to the issue is i have also a behringer xr18 to do aux mix i keep the aux to post fader and then i go to each channel and assign this channel as pre fader for a specific mix the reason i do that so i can control the volume in the aux fader to be independent and the same time i can send the amount of volume from channel fader to this aux i can't find the same way in presonus rml32ai , i can assign the aux mix to post fader put i can't assign each channel for this mix to be pre for example if i have to aux mix 1&2 both ARE POST and i want channel 1 to go to AUX 1 AS PRE AND CHANNEL 2 GO TO AUX 2 AS POST how can i do this BECAUSE WHEN I CHANGED CHANNEL 1 TO POST IT WILL BE CHANGED FOR BOTH AUX MIX 1 & 2 PLEASE ANY SUGGESTIONS thanks |
