Please excuse my ignorance in advance
I just purchased a 16.4.2AI ( previous A&H analog user), updated to the latest firmware, read most of the manual, setup my preset Fat Channel settings for each input, saved the scene for rehearsal yesterday. connected all sources and turned the unit on. unit boots normally but the GR meter is max'd and there is no indication of any signal on the board. I do have firewire connected to an approved cardbus adapter and using UC which seems to be working as advertized. Any clues in resolving this issue would be greatly appreciated. |
try this, Save your settings on your PC... then go into the scene page on the board and set it to scene 1 that sets the board to a -0- and a good starting point. I would also disconnect the puter first so it is not in the loop as you are figuring this out (process of elimination). If this does not work do a total reset (which will dump your scenes and presets so save em first!) and you may have to re load the update again if it got corrupted. Also look at how you are supposed to set up your PC for audio as there are videos available to streamline your puter and get rid of stuff that will mess with the audio processing.
I wanted to thank you for the heads up on zero out. signal path is fine now. I am just wondering what I could have done when using the presets for Fat Channel that would have made the GR max out and not allow signal flow even on channels that had no gate....
oh well I will figure it out. Thanks again |
2020 here for anyone who is currently having this issue. I own the 16.4.2 and this has been happening for months now; and I've tried every scene recall, fat channel fix, firmware reinstall that anyone has recommended in the forums.
This is a very much known issue by Presonus with its classic boards. some say it's a heat issue, others say it's with the flash memory, maybe a combination of both. Unless you buy replacement parts and do a fix yourself, which costs around $200 for the PCB with the flash memory, the repair will be $235 without shipping (which for me would be over $100). Do yourself a favor and put that money towards a Mackie or an Allen and Heath. A company that knows about this defect and does nothing about it, doesn't deserve your money. |
