I want to connect Presonus 32.4.2ai mix to notebook Win without router.
Only with ethernt cable. I want to connect it to UC surface. In Uc surface in Wired connection is mode Static Self Assigned from manual: Static Self-Assigned Mode. When two network devices are directly connected to each other or a switch, rather than to a network router, they cannot have their IP addresses assigned dynamically. In this case, the devices must be able to self-assign their own IP addresses. The most common direct Ethernet connection scenario is while using a StudioLive AI console mixer with a StudioLive RM/RML mixer in Stagebox mode or to connect your Windows Touch computer directly to your StudioLive mixer to run UC Surface wired, rather than wirelessly. In this mode the mixer will automatically assign itself an IP address in the 169.254.0.0/16 range, allowing connection with other devices in the same IP address range. Can it work? Some experiences? Thanks, Petr |
