Status No Driver-Unlinked
Hi pls help me my pc not have firewire 800 I put in my pci card 400 w adapter no find my mixer my pc working good whit6h my old 1602 thx Carlo
Carlo De La Cima
Musico Compositor y cantante saludos compre una 1642 AI Para remplazar mi 1602 pero no se quieren instalar los drivers en mi PC windows 10 (64 B) he tratado el 201 last 181 uc y nada mi version es SL 1.0.9194 ya no se que mas tratar con la anterior no tenia ningin problema mi pc tiene fireware 400 le puse un cable al #2 adadter de 400 a 800 logra conectar con el control 2.01 pero los driver para que la PC reconosca a la mixer no la ven. agradecere su ayuda Carlo Cima Music Studio |
There are two things you want to check:
1. The AI mixers and the 16.0.2 are two different platforms with their own Universal Control packages. You have to install both. 2. You cannot use adapters to go from FW400 to FW800. You have to use a bilingual FW400 to FW800 cable to connect your 16.4.2AI to a FW400 PCI card. Note: "no driver" = no working connection between computer and mixer. "unlinked" = no two mixers connected together. |
thanks for you fast respond
I have conected bilingual cable 800 - 400 may be my PCI is not conpatible my mixer reconoced 201 control universal its work my firmware 1.0.9194 my plataform Windos 10 my pc dont instal drivers for the mixer Carlo
Carlo De La Cima
Run the uninstaller for UC 2.1, which will remove all traces. Then reinstall 2.1, which is the driver for the 1642 AI mixer. Make sure that the firmware for the 1642 AI is current version also. Then hook the 1642 AI and make sure the connection works.
If the 1642 connection is ok, now you want to install UC version 1.74, which is the driver package for the 1602. Also make sure that the firmware on the 1602 is a match for UC 1.74. Connect and verify the 1602 is working correctly. If your equipment is registered, you can get all the correct software and firmware for each product in your my.presonus account |
Although it may seem a bit confusing, Matt is 100% correct for your setup. You must follow his directions in the order given to co-install the two different drivers to run your AI and 16.0.2.
Well said Matt.
Skip
hi
No, I have conect only 1642 I try change my PCI fireware card for one aproved for presonus THX Carlo
Carlo De La Cima
I change my fireware card by aproved preonus a my problem same
Carlo De La Cima
Carlo, I would suggest you open a support ticket. Look in my signature on how to accomplish this. Tech Support will get you sorted, my friend.
Skip
Skip
thanks I change the mixer i have a new 24 42 AI
all is ok Carlo
Carlo De La Cima
