Can't figure this out. Channel one, when selected, always flashes, the blue select light. No other select button or ,load, paste, copy, button flashes. No other channel select button flashes when selected. Only channel one when I select it. How do I get it to stop flashing or what does that mean?
Figured it out. In uc surface, channel 1 settings, is an option for "key source input". Not sure what that does, it was set to channel 1, set it to off and the blinking went away. Thanks
tracymckinney wrotean option for "key source input". Not sure what that does, It allows you to set the control signal for your compressor to a channel other than the current one. eg, the compressor on the bass guitar could be "driven" by the kick drum,
Karyn
The SL 32.4.2.AI and 24.4.2.AI have a button for the sidechain function, but the 16.4.2.Ai not. Have a look at your "StudioLive AI-Series Owner's Manual" and its section "Sidechains" (used to be section 4.1.4). A single channel blinking indicates its being sidechained to the channel you have selected. I hope this answers your question. Otherwise read the posts above and check the manual. Here are the links to the download pages:
http://www.presonus.com/support/downloads/StudioLive-3242AI http://www.presonus.com/support/downloads/StudioLive-2442AI http://www.presonus.com/support/downloads/StudioLive-1642AI |
