28 postsPage 1 of 2
1, 2
(despair mode)
It is now 8 month I hooked my StudioLive 16.0.2 in my studio.
Channel 1 to 2 : Microphones - XLR
Channel 3 to 6 : Live instrument with di box - XLR
Channel 7 to 10 : unused
Channel 11/12 : Vdrums Roland - Jack
Channel 13/14 : Audio input from my PC - RCA
Channel 15/16 : Mac audio (logic) - Firewire
Midi connected to an old JX10 as keyboard (logic)
Everything worked perfectly till this afternoon.
I turn on speakers and the studiolive. No sound from the microphones.
I unplug, replug check and find out that ONLY when I plug the microphones on the XLR of channel 13/14 or 15/16 or Talkback Mic I got audio signal. Any other channel play dead.
I test the jack input and it is the same. I did a factory reset using Universal Control. Turn all off...
Nada. This is turning me crazy ! How come only 2 channel and the talkback are alive ???!!!!?
Help.........
by matthewgorman on Fri Sep 04, 2015 9:55 am
Make sure the source on the channels is set to analog, and not digital.
Matt
S1Pro V4
by bernardsfez on Fri Sep 04, 2015 12:34 pm
The console was turned off for a few hours.
I turned it on and the channels are back to normal.
Good to keep in mind... but a kind of a "windows" solution. :D
by matthewgorman on Fri Sep 04, 2015 12:55 pm
They are little computers essentially. Reboot isn't just for modems.
Good luck.
Matt
S1Pro V4
by bernardsfez on Fri Sep 04, 2015 4:43 pm
matthewgorman wroteThey are little computers essentially. Reboot isn't just for modems.
Good luck.
I agree of course.
Facts is I did several on/off. I even unplug and turn on to be sure no more juice in the circuits.
Seems more time than 1 to 30 helped. :)
Thanks to share those terrible moments with me. ;)
by bernardsfez on Tue Sep 29, 2015 12:04 pm
The story is not over. :(
I'm using the mixer 4 times the week and it happen that only 2 channel (13/14 and 15/16) only work.
Not only with RCA input but also XLR input (Microphone).
I take care to turn on the main power switch, then last of everything the console, but still...
This evening I can't use it. :(
Does anyone have a suggestion ?
by gadget69 on Tue Sep 29, 2015 2:51 pm
Is this with a computer connected to the mixer? Sounds to me like a Tech ticket is in order they will get you up and running again!
Tower:
Asus Crosshair V formula Z motherboard
AMD FX9590 4.0 GHZ 8 CORE CPU
16GB 2400MHZ RAM CAS8
512 GB SSD PRIMARY HDD
1.5 TB THOSHIBA 128MB 7200 RPM DRIVE
2.0 TB WD BLACK 256 MB 7200 RPM DRIVE
AMD R9-290 4GB VIDEO CARD
Windows 7 P sp1
2006 Imac
Lenovo thinkpad Z565 upgraded with a Quad core processor, SSD and maxed out 8GB ram
Win7 Sp1
Mac 2006
Ipad 3,
Ipad 4,
Ipad Mini
Iphone 6s+
Audiobox USB
1818VSL
i2
Studiolive 2442Ai
SL 16.4.2 X 2
Studio 1/3pro
Sony Sound Forge 10
Engineer / producer
Owner Twilite Zone productions
Owner Studio G
by bernardsfez on Tue Sep 29, 2015 10:00 pm
Hello,
No computer is connected.
I wonder what is the difference between channel 1 to 12 and 13 to 16...
Bernard
by bernardsfez on Fri Oct 02, 2015 1:03 am
May be some pros can help me with a few question related to my issue.
I'm trying to figure the difference between channel 1 to 12 and 13 to 16.
I understand there is in the console a 12 input class A XMAX microphone preamp.
Is it assigned on input 1 to 12 ?
I also checked the Block Diagram of the console and re-tested using XLR input, TRS left and TRS right and it is the same.
Input meters are not moving when the problem occurs so the issue seems to be from the XLR/TRS input to the A/D Input Buffer. (Studiolive 16.0.2 Block Diagram)
by keysmcgee on Fri Oct 02, 2015 3:45 pm
Seems like a hardware problem.
Hardware: i7-7800X (OC 4.8GHz stable) - 4x8GB DDR4-3200 - 256Gb Samsung 960 EVO - 500Gb Samsung 960 Evo - Win 10 - FireStudio Project - HR824's - 2560x1080 monitor - 1920x1080 monitor - 1680x1050 monitor
Software: Studio One Pro 3.5 - Notion 6 - Assorted VSTs/VSTis from: Xfer, NI, Output
by bernardsfez on Sat Oct 03, 2015 12:38 am
keymcgee, thanks for your reply.
I bought my device in the US and now I'm in a different country (Israel) and it seems it is a kind of complicate to apply the international warranty :( and I'm trying to figure how we can solve this with Presonus.
I'm confident a solution will be found, but in the meantime, do you have any details about the problem you had and the solution that was applied ?
What was the technical issue ? Is part has being changed ? What did they told you ? :)
It will certainly help me to progress with Presonus if we have a precise idea of my issue.
It may also be important for Presonus to fix this issue if it is not an isolated case.
Many thanks for helping me with this.
Bernard
by gadget69 on Sat Oct 03, 2015 9:00 am
Yes, You need to contact Tech support and they will get you back up and going again.
Cheers
Tower:
Windows 7 P sp1
2006 Imac
Win7 Sp1
Mac 2006
Ipad 3,
Ipad 4,
Ipad Mini
Iphone 6s+
Audiobox USB
1818VSL
i2
Studiolive 2442Ai
SL 16.4.2 X 2
Studio 1/3pro
Sony Sound Forge 10
Engineer / producer
Owner Studio G
by moraldecay31 on Sat Oct 03, 2015 12:29 pm
Same exact thing happen to my 1602. Only last 2 channels worked. Had to send it in to be serviced.
by bernardsfez on Sun Jan 31, 2016 7:40 am
It took a bit of time before I get my StudioLive back into his place but...
Hopefully, Presonus team took the time to understand the issue and helped to get it sorted for the same price I would have paid in US.
I got even a little bonus with accessories. :)
Happy Presonus Customer.
by henrik@magazin24.se on Thu Dec 08, 2016 3:43 pm
Same thing with my 16.0.2
I turned it on, only ch 13-16 works.
Have not done anything since I last used it
and then every channel worked.
by wahlerstudios on Thu Dec 08, 2016 6:28 pm
It doesn't look like a factory reset can help, so get the board repaired in your service center. You will have to describe what the problem is. They will respond to it. Luthman Scandinavia KB in Hägersten is your distributor and probably also takes care for repairs.
SL16 | 32R | 16R | 16M
Apple routers | iPads | PreSonus SW5E & Motu AVB switches | Alesis iO Docks | Yamaha S112, S15e, S10e, SM12, SM10 | LD Systems Curv 500 | Galaxy Audio Hot Spots | Mac mini | Lenovo Laptop | Studio One Artist 4.6.1 & Pro 3.5.6
by oscarmonsalvo on Sat Mar 17, 2018 6:31 pm
Good day;
I'm repairing a studiolive 16.0.2 mixer with precisely the same fault, when turning it on it works fine, but when you turn it off and turn it on again they stop sounding channels 1 to 12, they only work 13/14 and 15/16, I would like to know how have solved, for what I see is a common and recurring failure in these mixers so it must have a simple solution (maybe some factory defect) :thumbdown: , the analog inputs work with the DAC PCM4204, all the reset inputs of the DAC (pin 10) they go in parallel so I do not think that's the problem, since I update the firmware and the problem continues, if I connect the mixer by firewire to universal control and I select channel 1 as a digital input if it gives sound, so the fault is DAC back, tomorrow I will review with oscilloscope to see if the analogous signal reaches to reach the DAC input, if so I imagine that the failure will be the DAC .... the three DAC at the same time !!!. .. Any suggestions?
:+1
by bernardsfez on Sun Mar 18, 2018 12:22 am
Mine was repaired and worked fine for about a year.
One day they were a power outage while the mixer was on and since then problem is partially back.
If I plug the mixer to the computer it loss all output.
I have to physically unplug the mixer, plug the computer (MBP OSX), wait for about 3mn, plug back and turn it on.
One thing I noticed, if I hear weird noise from the monitor (kind of "tack, tack, tack...") I know it will be ok.
If there is no sound I just redo the all operation.
Once working, it work for good.
by oscarmonsalvo on Tue Mar 20, 2018 12:48 pm
Well I tell you that I could solve the problem of the mixer.
The damage was in the 5V regulator that feeds the first 3 ADC and therefore stopped working the first 12 channels, the 5V did not reach the measurement point, only 3.3V arrived, the other regulator fed the output DACs and the ADC of the input channels 13/14 and 15/16.
The two regulators are on the left side of the main board, next to the connector of the power supply.
by bernardsfez on Tue Mar 20, 2018 3:08 pm
Hey nice, I could give it a try.
Do you have the ref of the 5V regulator or picture ? (anything to help)
Somewhere on this board ?
http://www.fullcompass.com/prod/501456- ... 410-PG1PWR
28 postsPage 1 of 2
1, 2
