Studiolive 32Ai, 24Ai and 16Ai Consoles with Universal Control Ai, SL Remote Ai, and QMix Ai
1 post
I have a problem in a StudioLive AI 24.4.2 mixer. The mixer lights go out. From channel 9 to the right including the top light bars and the display also stops working, (the backlight does not turn off). The audio does not stop working, but where there is no lighting, no control works. Turning the mixer off and on again, the operation is restored. I clarify that I have the mixer with 'APC' ups on line.Tengo un problema en un mixer StudioLive AI 24.4.2.
Se apagan las luces del mixer. Desde el canal 9 hacia la derecha incluyendo las barras de luces superiores y el display tambien deja de funcionar, (no se apaga la luz de fondo). No deja de funcionar el audio, pero donde no hay iluminacion no funciona ningun control. Apagando la mezcladora y volviendo a encender, se recupera el funcionamiento. Aclaro que tengo el mezclador con ups on line "APC".
1 post
