Studiolive 32Ai, 24Ai and 16Ai Consoles with Universal Control Ai, SL Remote Ai, and QMix Ai
Whats up everyone - first post here and first time using PreSonus as well.
I'm trying to set up my StudioLive 16.4.2 along with my Studio One 4 set up. It's the outputs that are messing me up.
In the Audio I/O Setup when i go to Output's it only lists my options as Ch 1-16 or 2TrackIn L and R. There's no "main output" option.
It was preset for Ch1 / Ch2 but of course during playback if i don't have Ch 1/2 pushed up then there's no sound. Also I should note I'm having to have the FireWire buttons on the top of Ch1 & 2 (the ones near the faders) pushed on as well in order to get any sound at all.
Hoping someone can dummy walk me through this lol. Thanks in advance.
by SwitchBack on Wed Oct 10, 2018 9:54 pm
Hi and welcome :)
What you see is all correct. You can return 18 channels of audio from your computer to the mixer: Ch 1-16 go to the firewire buttons on the 16 mixer channels, and 2TrackIn L and R go to both firewire buttons above the sub faders. Of those two firewire buttons the one below the '2 Track In' knob will put 2TrackIn L and R on the main fader. The one below the 'monitor' knob will put 2TrackIn L and R in your phones (and on the control room outputs).
by willsamstutz1 on Thu Oct 18, 2018 7:18 pm
SwitchBack wroteHi and welcome :)
Man this kinda set up is all so confusing to me lol. Coming from a Korg 32XD where its basically plug and play...this is a bit daunting.
That being said - its working lol. My next question would be - is there a way for me to cut the flow through sound. For example, even when I do not have any tracks armed to record, if i press anything on my keyboard the sound goes through. I can still control it with my master fader but I was wondering if theres a way to cut that sounds completely or does it just come through no matter what?
Thanks for the help above!
by SwitchBack on Fri Oct 19, 2018 2:51 am
Did you use one of the StudioOne templates to set up your session? Because that would make things easier.
The SL16.4.2 has a 32 sends / 18 returns interface built into a 16 channel mixer. Of the sends (to the computer) the last 16 are user configurable (e.g. for sending the aux inputs or mixer outputs to the computer) and the first 16 are hard-wired to the mixer’s analog channel inputs (always sending those inputs to the computer). The 18 returns (from the computer) go to the firewire buttons on the mixer, the first 16 to the mixer’s channels and the last two to the main/monitor section.
The 16.4.2 templates in StudioOne will set up a session where the mixer’s channel sends are mapped to S1 tracks, a bus on every track is mapped back to that channel’s firewire button on the mixer, and S1’s main output is mapped to the firewire buttons in the main/monitor section of the mixer. This setup allows you to use the mixer as an ordinary 16-channel mixer (mixing its analog inputs to its analog outputs). In addition to that the firewire buttons on the mixer channels allow you to replace any of those analog inputs with its track returned from the computer. This will only affect the mixes on the mixer, not what’s sent to the computer (which is always the mixer’s analog inputs).
So, with your keyboard connected to the mixer and S1 playing some tracks, you only engage the firewire buttons on the mixer channels you want to hear playing from S1. And in S1 you only arm the tracks you want to record from the mixer. During the recording session you will listen to the mixer’s mixes (not to 2-Track). And after the recording session is done the 2-Track return is there for you to play back and listen to the mix from S1. Or you can engage all the firewire buttons on the mixer channels and do the mixing on the mixer.
Hope that helps :)
