1. Issue description / summary:
Send to Notion Mobile running on iPad iOS 16.5 from Studio One 6.1.2 is not working. 2. Steps to reproduce: ...Try to use the Send to Notion feature in Studio One 6.1.2. ...Make sure Notion Mobile is open on your iPad iOS 16.5 and is on the same network. 3. Observed behavior: You get a message stating: "Notion Mobile or Notion 6 and later, must be installed on this computer or in the network. Studio One could not detect that Notion is currently running." 4. Expected behavior: Notion Mobile should be detected and able to receive song data from Studio One since it is open and running on an iPad on the same network. 5. Your device Mac Studio M1 Ultra. 6. Your operating system macOS 12.6.6. Optional: 7. Solution, suggestion, workaround This feature works as expected when using Notion Mobile on the same Mac computer on which Studio One is open.
Jonah Walton
Producer | Engineer ------------------------ PLEASE ADD YOUR SYSTEM SPECS TO YOUR SIGNATURE ------------------------ Mac Studio M2 Ultra 24C CPU / 60C GPU 64GB/1TB LG ULTRAGEAR 32GP83B-B 144 Hz 32" Monitor 2560 X 1440 MacBook Pro 16" M3 Max 16C CPU / 40C GPU 48GB/1TB macOS 14.4.1 - RME UCX II & Babyface Pro FS Plugins - Too Many |
Hi Jonah,
You are getting this error for certain reasons; * All features must be unlocked * Your local modem must allow the file sharing * Studio One > Preferences > Network > Allow remote controls apps to discover this DAW * System Settings > Network > Firewall > Allow Notion Mobile * System Settings > Network > Firewall > Allow Studio One * System Settings > Network > Filters > Disable all security & antivirus softwares (as soon as you disable all the security softwares, you can easily transfer your files) Thank you Sinan
Sinan C. Eroglu
QA Specialist at PreSonus Software Ltd, Hamburg, Germany --------------------------------------------------------------- iMac Pro Intel i9 128GB RAM, 16 Core GPU, 1TB SSD MacBookPro Intel i7 8-Core GPU, 16GB RAM 256GB Flash SSD MacBook Air M2, 8GB RAM, 500 GB Flash SSD Mac Mini 2,6 GHz Dual-Core Intel Core i5, 16 GB RAM iPad Pro 12.9 (5th Generation) RME Fireface UCX Official Artist of Kemper Profiler, EMG Pickups, GHS Strings Spotify: https://open.spotify.com/artist/5bAM9... http://sinancemeroglu.com http://youtube.com/sinancemeroglu |
sinancemeroglu wroteHi Jonah, I have all these settings set properly, except for the ones that do not pertain to Mac users. I have no antivirus on my Mac, and my modem allows file sharing.
Jonah Walton
Here I can’t still reproduce your issue. We deeply tested and investigated the file transfer and there is no way to reproduce. If you have the problem, please try to disable your firewall software as I mentioned on my previous reply. Thanks Sinan
Sinan C. Eroglu
sinancemeroglu wroteHi, Hello! I have no firewall software at all.
Jonah Walton
Hi
Please make sure that you unlocked all features by log in your Sphere account. As we can’t reproduce the issue, I can’t help. Thanks a lot Sinan
Sinan C. Eroglu
sinancemeroglu wroteHi I have done this as well. I'll keep testing.
Jonah Walton
We are also investigating this issue. Thank you Sinan
Sinan C. Eroglu
