Discuss Notion Mobile here.
I have created a simple score- I’m a beginner!
To help me play, I’ve added finger positions. When exporting to musicxml format, the finger positions are incorrect.
Here’s an example.
Select fingering menu, select the finger number you want, select a note on the bass staff. The finger number is correctly shown against the note on the bass staff.
Export the file as musicxml. Open the musicxml file in a text editor and see that the <fingering> tag is attached to the corresponding note in the treble staff.
Sometimes it does it correctly. I enter them exactly the same way.
I’ve attached three screenshots, one of the score, and two of the xml - one correct, the other incorrect.
Correct xml
Incorrect xml
Score
by soiihrca on Thu May 18, 2023 8:30 am
In case it helps anyone else, I reported this to support who confirmed they were able to reproduce it and it’s been passed through to QA for investigation.
by sinancemeroglu on Fri May 19, 2023 2:56 am
Thanks for reporting that issue. We are aware of that and it will be fixed on the next update !
Best
Sinan
Sinan C. Eroglu
QA Specialist at PreSonus Software Ltd, Hamburg, Germany
iMac Pro Intel i9 128GB RAM, 16 Core GPU, 1TB SSD
MacBookPro Intel i7 8-Core GPU, 16GB RAM 256GB Flash SSD
MacBook Air M2, 8GB RAM, 500 GB Flash SSD
Mac Mini 2,6 GHz Dual-Core Intel Core i5, 16 GB RAM
iPad Pro 12.9 (5th Generation)
RME Fireface UCX
Official Artist of Kemper Profiler, EMG Pickups, GHS Strings
Spotify: https://open.spotify.com/artist/5bAM9...
http://sinancemeroglu.com
http://youtube.com/sinancemeroglu
